macready's Avatar
checking transmission fluid
i have a '85 911 and my shifting is not too good in 1st and 2nd gear. by process of elimination, im first going to check my transmission fluid level just to make sure its full. what is the best and easiest way to check the fluid. is there a way to get to the transmission filler plug by moving one of the back seats or do you have to go under the car?
if you can go through the interior of the car to get at the filler plug does anyone have any tips or directions as to how to do this the proper way?
or
if you have to just go under the car, how do you get under the car while keeping the car level so the fluid is level when you check it?
thanks...for any info!
1985 porsche 911 carrera
Old 05-12-2004, 07:45 PM
its all done from underneath. i would suggest just changing the fluid to swepco, instead of just checking it. then at least you know whats inside of there. i would start there
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 05-12-2004, 08:12 PM
VincentVega's Avatar
Yep, all from underneath. 4 jackstand will keep it nice and level. It doesnt have to be perfectly level, just get it close. 2 thumbs up for Swepco.
Old 05-12-2004, 08:27 PM
macready's Avatar
thanks for the info....and do you guys use a hand-operated oil pump when replacing the transmission fluid? is this the only way to get the fluid in the case?
Old 05-12-2004, 08:49 PM
Randy Webb's Avatar
what size allen wrench do yo need for the 1970-71 tranny drain plugs?
Old 05-12-2004, 10:09 PM
Binge User
Schrup's Avatar
According to our host it's 17mm.
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_tranny_pg3.htm#item13
But on the PET it looks like an external hex nut maybe 17mm
Paul
Old 05-12-2004, 10:51 PM
macready--
Make sure you loosten the fill plug before draining tranny fluid. Don't want to drain and not be able to refill.
You have a 915 tranny. I just replaced the bushings and shift coupler--made a world of difference. Trans shifts much better now. There are good threads on this site (including some I started). Let me know if you feel you need to tackle the bushing replacement, I can give you some tips that may save time.
Alan
1988 924 S
500 in US
Black (the only color)
82 SC Guards Red/Black . (Sold)
SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade
Old 05-13-2004, 03:14 AM
Irrationally exuberant
ChrisBennet's Avatar
I doubt your fluid level is at fault unless you have a noticable leak. 1st and 2nd are the first gears to wear out usually.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-13-2004, 03:40 AM
HarryD's Avatar
Hi,
I changed my fluid recently. Being a tightwad, I used a funnel and 3 feet of 3/4" tubing. I warmed the new oil in a pan of warm water for a bit to help it flow. stuck the open end of the tube in the fill hole, and held the funnel higher than the car. I added some oil and continued to do so until it overflowed out the fill hole.
I pump would be easier, but it did not take very long with the funnel.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-13-2004, 10:36 AM
I went to autozone and for $3 they have a transmission filler hose which screws onto the swepco (or any other) gallon. It even has a handy twist function to to start & stop the flow. Added about two feet of additional tubing (from home depot) and just set the swepco container on the rear wheel. Punch a tiny hole in the gallon container for easier flow (above the oil level of course).
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 05-13-2004, 11:54 AM
HarryD's Avatar
Pretty cool but the only dark side I see to that is that after I put my 3 quarts of SWEPCO into the tranny, I have one qt in an unsealed container.
Harry
2020 MB E350 4Matic
Old 05-13-2004, 11:58 AM
Or you could just make a pump using a juice bottle, some tubing and compressed air. See my post in this thread.
-Chris
Old 05-13-2004, 12:02 PM
HarryD's Avatar
I made a little DIY for this job. It includes a picture of how I filled my Transmission.
You can see it here (http://members.rennlist.com/harryd/Trannyoil-Change.htm). Very similiar to the one in 101 Projects.
Harry
2020 MB E350 4Matic
Old 05-13-2004, 09:00 PM
