installed cat-by pass..now idle problems
Could use some help.
i have a pretty much stock 81SC...everything has been running fine..installed a bursch cat-bypass. Took it out for a test drive..nicer sound....a little better throttle response. Problem...when I returned...the car would stall or not idle when standing still. I replaced the 02 sensor in the by pass pipe. Again, it doesnt seem to want to idle when warm..has something changed...mixture? idle setting? Any comments would be appreciated. Andy 81SC |
D idn't E arn I t
That's weird. Did that to mine a year ago and didn't have a single issue.
Thinking something else broke at the same time. Coincidence probably.
AOC/Hogg 2028 |
just to clarify...the 02 sensor was reinstalled after installing the by pass....it has not been removed.
bump
Bye, Bye.
I would check the wires going to the O2 sensor, sounds like one pulled out when you put the sensor back in.
Elvis has left the building. |
D idn't E arn I t
Relay under passenger seat '83SC
Possiblilty it could be frequency valve relay just dropped dead? Unplug it and see if it runs any differently. Good luck
AOC/Hogg 2028 |
sounds like the O2 sensor,unplug it completly and check for change.Probe a multiscanner into the green wire,or the only wire if it`s a non heated sensor and check for a reading.
my life begins at 150MPH |
