geof33's Avatar
RSR project week deux... Engine questions...
So, the deal is this on the motor. I've pulled the plugs, drained the oil and pulled the sump. Found NOTHING out of the ordinary. The PO said he heard a "poof" one cylinder died, and oil was coming from the exhaust. There is oil in the air box, and in both exchangers.
Plugs are a bit carbonofied, but none looked to be fouled in any way. No stray metal bits in the motor, nor any sign of metal wear on the magnetic thingie in the drain plug.
Any ideas as to why this thing might have a dead cylinder???
A shot up the guts:
Progress was good, more dismantling and the begining of MANY hours to come of cleaning, cleaning and more cleaning!!
The shots:
Thine worthy steed comforting it's breathen:
Any idea what the heck this might be??? It's McGyvered into the fuse box...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-16-2004, 09:41 PM
konish's Avatar
Sheesh, that rats nest looked like my car that had a POS aftermarket alarm. The previous owner said he removed it, but a LOT of it remained
R/
Dustin
Old 05-16-2004, 10:25 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
get a decent voltmeter and turn the key to hot and go through the wires and tape off the ones that are not hot. it should be pretty straightforward then you trace them to where they come from and simply take them out. the PO on my car had two alarms left in it without the horn, just the wiring, i ended up taking out about a hundred or so feet of 14 guage wire. so much nicer looking and no loose ends to worry about. have fun! that white car looks great btw.
74 911s neverending story. two feet and a jetta for now.
Old 05-17-2004, 12:35 AM
