"C-Rations"
Help!!!
I am trying to install my four spoke wheel to my '85 Carrera and do not want to damage the horn pad. How does it come off?
John The Stable: 1985 Carrera Cabriolet (RoW) Sold 2002 Chevy Tahoe LT (The Wife's) 1999 Chevy Silverado (Parts Hauler) 1969 Volkswagen Beetle (Purchased From Original Owner) I'm slower than the guy in front of me, but faster than the guy in back of me. |
Somewhere in the Midwest
pulls straight toward the driver..really...there are sprung tabs that hold the pad on.
"C-Rations"
I tried to pull on it. It seems like it's really attached well!
John...IF it works like the horn on my 1972...and it's a big IF...unhook batteries to save your ears. Push straight down on the pad and twist to the left....This shouldn't damage your pad to try. No risk, might work...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Its scary, but wiggle a little and pull back. I sheet you not, that's how they are attched...unless you have a different kind of 911 Carrera.
"C-Rations"
Hang on I'll post a pic, Souk.
Sometimes they are really on there. I usually grab both ends, as close to the center as possible, and pull back semi-sharply while inducing a little forward-tilting leverage at the same time. In other words: Prying it up a little while pulling back so the bottom half pops off first. Good luck!
"C-Rations"
I know I have to transfer the signal cancelling ring from one wheel to the other.
Disconnect the battery...then pull the horn pad straight off...it is on tight. Then you need a deep socket 27MM. Once the wheel is on and the wires connected, DO NOT put the horn pad back on yet. First, re-connect the battery...if the horn sounds your wires are backwards. If the horn does not sound then the wires are correct. Disconnect the battery and then install your horn pad by pressing it on until the springs seat over the posts. Then re-connect your battery. Drive. Get ticket. Grovel to the wife.
Sam '02 996 TT '07 Audi S4 Avant '88 Carrera (Sold) |
Be careful not to break that tab for the turnsignal cancel.
I was kidding about the "different 911 Carrera" thing..you have the same wheel and horn pad as everyone else who's got fat pig Carrera... It will pop off...secure the wheel so you don't break the tab, and give it a go just like the psots above suggest. |
"C-Rations"
Got it!!! Stand by for finished product.
Oh, and Sam, I already have a 27mm deep socket in my arsenal of tools! Did you need a 6pt or 12pt?
yeah, listen to your little brother...he knows best.
"C-Rations"
Finished!!!
All done and the horn works, too! Some before and after pictures.
Hmmm....seems like you can see all the gauges with the stock unit, as opposed to.....
![]() --Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
"C-Rations"
I took it out and drove it. I love it!!! It is much easier to control with the stock wheel. And, yes, you can now see all the gauges clearly.
nice wheel..
On long drives that wheel makes easier to hold on to. I rest my arm on a leg and it's an easy reach to the spoke for good wheel control.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Bye, Bye.
Isn't it amazing that an "aftermarket" steering wheel looks more "Porsche" than the factory wheel? Interior looks great!
Elvis has left the building. |
"C-Rations"
Actually, Scott, that is a genuine Porsche wheel. That, in fact, is the actual factory wheel that came on the car when it was new.
Thanks for all the help and compliments my fellow pelicanheads. Sorry I have not posted my official "new owner" pictures. I have been busy with finals at school and preparing to sell my home and move. They are coming soon!
Bye, Bye.
Sorry John, I had the wheels reversed. I actually prefer the aftermarket wheel over the factory wheel. That being said, I still say your interior looks great either way.
"C-Rations"
Thanks for the compliment, Scott.
Yes, I know a lot of Porsche owners like the aftermarket wheels, especially the 930S wheel. Who knows, maybe I will change my mind down the road. For now, it's factory all the way! I don't know if you noticed, but I still need to change the shifter knob back to the factory version.
Thread Tools | |
Rate This Thread | |
