Zeke's Avatar
Storing MFI Pump..suggestions?
Looks like I will be hanging on to a 2.4 T motor indefinately. I wasn't sure what I was going to do with it, but now I know it will sit for a long time. It doesn't run. Was there something to fill the MFI pump with for preservation "on the shelf?" The cyls already have the Marvel Oil. It was sprayed in and distributed well with a blast of air out of a wand inserted thru the SP hole. TIA.
Old 05-19-2004, 08:53 AM
Friend of Warren
Fill with clean motor oil, plug the injector line outlets and store in a plastic bag.
Kurt V
Old 05-19-2004, 08:55 AM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
I can store them for ya!! Are you keeping the MFI pump and throttle bodies?? Im looking for a set actually.
I think Kurt has the best way to go though. Just make sure there is no water moisture in the bag when you seal it and you should be fine.
74 911s neverending story. two feet and a jetta for now.
Old 05-19-2004, 09:30 AM
pwd72s's Avatar
Why not just drop it in a gallon can, fill with oil? Oil doesn't have to be synthetic...
Old 05-19-2004, 10:08 AM
Grady Clay's Avatar
Milt,
Try this 2c. I’ll be glad to offer 3c.
Storing and preserving an engine
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-19-2004, 10:36 AM
Zeke's Avatar
Thanks, Grady. I don't have the luxury of running the engine to go thru all the steps, but I will hand turn the pump. I'll try to get it to induce some MMO laden gas or mineral spirits as well for protection on the top side.
Old 05-19-2004, 01:35 PM
Zeke's Avatar
Originally posted by Wayne at Pelican Parts
In our MFI tech section, there is a factory publication with details on the proper long-term storage of the pump:
http://www.pelicanparts.com/techarticles/911_MFI/TipMFI.htm
-Wayne
It tells me, 'coming "soon" ' Same as I got before asking. But, if it is pretty much the same as what's here, I'm good.
Old 05-19-2004, 03:07 PM
