Head Temp Sensor Tool
For those who are interested, the special tool for removing and installing the cylinder head temperature sensor....
14mm 3/8" drive Flare nut socket from Snap-On: Part# = FRXM14 I did my sensor this evening and it took 1 hour without the tool. If I had the tool, it would have been done in 1/2 hour. I am ordering the tool to snug up my sensor ( just to check) as I used needle nose pliers on the install. I will use this tool again in ten years. Anyone wanting to borrow it in the Philadelphia area is welcome.
The Fox Carrera |
UFLYICU
Buy any cheap 14mm deep socket, and grind a slot in it. Works like a charm.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
ZOANAS....
I tried that and the sockets I had were so tough I couldn't grind a dent into them. What are you using to slot the socket?????
The Fox Carrera |
disc cutter.
UFLYICU
I used a Makita angle grinder with a 3" disc. I also used a dremel to smooth it out.
Irrationally exuberant
I just cut a slot in a 14mm box wrench. It's not like I use it for anything else.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Location: member Central PA Region PCA , Home of the Hershey Swap
Like the others I cut a slot in a Craftsman 14 mm deep socket with my 3.5" Dewalt grinder. The socket was $2 or 3.
regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
Schleprock
I think I used a flare nut wrench. But mine was easy because the engine was on a stand, out of the car.
Kevin L '86 Carrera "Larry" |
-Chris
Photo of the one I made with my Dewalt grinder and a Craftsman 14 mm Deep Socket? Do you think this voids the craftsman warranty?
All righty then...You folks have convinced me.
I bought a $2.99 14mm deep socket from Sears....My neighbor has a grinder and we'll soon have a special tool..... Thanks again
The Fox Carrera |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Hey rbcsaver...
I will cover your warranty...Just return your DAMAGED tool to me and I'll replace it with a BRAND NEW 14 mm socket..OK?????
The Fox Carrera |
