"Cheap is expensive"
Alignment question
Once I lowered the front of my car I can no longer get the camber back to spec. What can easily be done to offset this without camber boxes?
Thanks |
how much is it lowered based on using stock tire diameter ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Raised RSR Front Spindles.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
It's lowered approx. 1/2" so I was able to just use the rack spacers for bump steer.
What are RSR Spindles? Thanks |
The camber is -1.8 and -1.3 deg. in the front, which could be ok since I have the old OE rubber bushings in the A Arms and the struts. Then I just have to set the tire pressure.
Some filing of the holes at the strut top will give you a little more range of adjustment, maybe 1/4 degree. If you need more, you can get offset camber plates which are good for about 3/4 degree additional.
Chuck Moreland - elephantracing.com - vonnen.com |
Thanks guys, I will have to see if any of this is worth doing since my car runs and drives fine. Just want to be proactive if it could lead to trouble.
