Guest
Posts: n/a
who makes factory colors in a spraycan
Im in the process of cleaning out my front trunk. I removed all the wires so i can sand down and paint all the scratches. I was going to paint it black but i was told that there is a company that sells factory colors in a rattle can. Hopefully viper green. Anyone know who that is? Thanks.
Paintscratch.com
Stay away from my Member
www.towerpaint.com
They can mix to code, or to match a small sample piece you can mail to them. I have used them several times with good results. Note that if your car was painted by a PO and/or more than a year or so ago, you are better of matching the existing paint. You can't rely on the original paint formulation nor the effects of sun fading, polishing etc.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Joseph
Check with professional paint supply shops. Many will custom mix colors from your paint code and package into spray cans. I had 4 spray cans of Grand Prix White packged into spray cans for about $35 last year. It took about 20 minutes in the store while I waited. Joe
Joe Frantz 73 911 T |
Guest
Posts: n/a
Thanks guys. I looked into paintscratch.com and they want 30.00 per can. Sounds like a good deal to me.I havent looked into towerpaint.com yet.
Joe |
Tower Paint is less expensive and the spray tip is superior. They sent me about 4 tips with my last order as well.
Warren & Ron, may you rest in Peace. |
I have used tower paint... been happy with the results also
canna change law physics
I bought 1 gallon of paint and had the last 4th quart loaded into spray cans, touch up applicators, etc, and they charged something like $5/can.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Guest
Posts: n/a
Thanks guys. I went with Tower paints. I got 2 cans for 30.00 plus shipping vs 30.00 for 1 can. Each can is said to cover 4-6 square feet. Should be here in a week though. I wanted to put all my wiring back this weekend. Oh well.
Guest
Posts: n/a
Here is what it looks like before the paint. There was only surface rust which i sanded down and will por15 over the weekend. Im going to scuff the paint with a light sanding, then clean it with thinner then prime it. Then i wait a whole week for my rattle cans and spray it with factory color. I cant wait to see the results. After that i will do the engine compartment . The motor was pulled out and is now on loan to my freind Tyson. He Threw a rod so is now building his short stroke 2.5 .
You do not have permissi
There are those little Preval spayers also-to use with a mix of good chemicals, but those seem better for small touch-ups.
I just wonder how spray-cans will have a good proper mix of hardener and thinner. The two-part chemicals always seem to work better.
Meanwhile other things are still happening. |
I did a search on Tower paints found nothing, do they have a web site?
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
The link is at the top of this thread.... www.towerpaint.com
Thanks, I'll go stand in the corner now...
