Broke
Westy's Avatar
Lot's o Squeakin' down there
I jacked up the front of my SC, checked the bearings and brake pads, polished the rims, then put it back together. OK, simple enough,,,except now the front end squeaks. It's like a Chevy ball joint sound, and happens when you bounce the car on it's suspension. I couldn't have hurt anything, and I know I have poly bushings on the sway bar. Is there a lube for this problem? Is there something I'm not aware of down there that needs attention.
Thanx, Brian
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 05-19-2004, 08:14 AM
Broke
Westy's Avatar
I'm gonna try this again. That sqeak is really annoying.
93 968 Cab
Old 05-21-2004, 06:57 AM
My car recently did the same thing following alignment and corner balance after a complete (shocks, T-bars, bushings, tie rods, bump steer) install. I isolated to the right side of the car, moved the A-arm up and down and the sound went away.
Old 05-21-2004, 07:12 AM
Binge User
Schrup's Avatar
I recently replaced my suspension, & after I had a horrible squeek. Turns out it was my front hood latch.
Paul
Old 05-21-2004, 07:23 AM
Broke
Westy's Avatar
Hmmm, hadn't even thought about that. Thanx
93 968 Cab
Old 05-21-2004, 07:26 AM
MuffinMan's Avatar
I had a similar occurrence last year. I have polyurethane bushings and had no squeaks. I put my car on a lift on a very hot day (~95F), and when it came off, the rear began squeaking. It's gotten worse over time, and I'm guessing that when the suspension went to full droop, it moved enough that it was no longer well-lubricated when moving back to its loaded position. I believe it can be fixed by disassembling the suspension, re-lubricating the bushings, and putting everything back together again. I plan to install the Elephant polybronze bushings so I don't have this problem again in the future. I'm guessing your squeak comes from a similar issue. Do you know what kind of bushings you have up front, aside from the sway bar bushings?
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
its probably your sway bar bushings. not sure what kind of grease i used but i had the same thing, greased it up and it stopped.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 05-21-2004, 08:05 AM
Send a message via AIM to eurocarrera
The problem with the poly bushings is that they are too hard too twist, so they slide and will need grease. Whereas the stock rubber ones were designed to not move but twist, and cause no squeak, but they aren't as accurate for alignments, and need to be replaced. Get the best of both worlds, and get some bushings from Chuck at Elephant racing - they work great, and are a once in a lifetime replacement.
Bill Atkins
mrpeabody37@yahoo.com
1985 Carrera Coupe ROW - SOLD
Old 05-21-2004, 08:13 AM
Broke
Westy's Avatar
Thanx Bill, I'll pay about anything (well, maybe not) to eliminate this noise
93 968 Cab
Old 05-21-2004, 08:16 AM
