Still trying to get tach working
I’m still struggling to get my tach working. I installed my 2.2 in my 71T. It has a Marelli distributor. The black and purple lead is connected to the contact on the side on the distributor and leads into the RPM transducer on the rear electrical panel. I know I have continuity to the tach. Since the car is a collection of bits from various cars I don’t know if everything matches. I’m not sure if the RPM transducer is right with the distributor.(see pics below) Curious thing is that when I connect a light bulb across the distributor I cannot seem to get the bulb to come on when the contact opens. The car sparks and runs fine. What am I missing. Do I have the wrong transducer. Any ideas?
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 05-19-2004, 09:39 AM
Early_S_Man's Avatar
Porsche Crest
Steve,
The Rpm Transducer/Speed Switch/Speed Relay isn't the problem ... that is the correct one for a carbed engine, and if it was shorted from a rusted transistor rattling around inside the case ... your ingition would have problems running!
Are you still using a stock Bosch CDI unit?
To get a test lamp to work ... try connecting it to +12 Volts and the distributor terminal, rather than across the distributor to ground.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-19-2004, 10:00 AM
Warren, yes I am running the stock CDI unit. However the PO was running a permatune unit with the speed switch. Would that make a difference. I put the CDI in because I knew it was a good unit and wanted to eliminate unknowns when I first started the motor after rebuild.
Steve F
69 911
71 911
87 Carrera
Old 05-19-2004, 12:37 PM
Porsche Crest
Steve,
No real difference of any significance between Bosch and Permatune as far as the RPM Trancducer is concerned.
The tach you have may be a unit intended for use with a ballast unit ... some/most of those tachs don't work with a point-triggered CDI system.
You may want to try building my bargain-bin tach calibrator that can also be used for such tasks as testing CDI units and RPM Tranducers ... as a pulse source ...
Warren Hall, Jr.
Old 05-19-2004, 02:54 PM
