I'm installing a TEC3 in my buddy's race car, but I'm not really a
mechanic and need to know some answers. What would be a typical engine timing scenario for a 3.4 Carrera with cams, high compression, and a stock injection system? Also, does anybody know what the lb/hr rating is on the stock injectors. Any info OR advice on the TEC3 would also be greatly appreciated! Thanx in advance, Pete
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
Author of "101 Projects"
Rick Clewett is the expert on this stuff (www.clewett.com). However, if you didn't buy any system components from him, I probably wouldn't call him up for free advice.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Navin Johnson
Ive done a few Tec installs, as well as with Haltechs...and tuned some piggy backs
You will need to build a base map...Tec 3 has a "wizard" that will create a *.bin file that will get the car running. You enter the basic engine configuration...and it makes a basic "bin" file After you have the car running... it becomes a trial and error tuning scenario...A wide band 02 sensor, and accurate EGT gauge, and a knock sensor.. are required tools A quick and dirty timing map may be 5 deg at 1000rpm, and 30 deg at 3000rpm... Optimum timng and power will only be realised through dyno tuning....You can get close approximations through trial and error on the track... Basically you tune each load range to have safe fuel delivery ie richer than 14.7 then you load the dyno and dial in timing till you have max power..when you have found the advance that delivers max power.... dial it back just a bit... There are lots of other tricks available to tune an engine with EFI... Clewett is helpful... but you can always call electromotive for support
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Irrationally exuberant
A spreadsheet someone sent me lists those injectors (Bosch 0 280 150 158) at 25.9 lb/hr.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
