Got the alternator rebuilt today
$32.50 plus tax. Whheeeehaaaaa Sure saves over the cost of a new one. Doides were fine, it needed a new voltage regulator.
I took it out last evening in 25 minutes flat. The first time took almost 2 hours. Reinstallation will take a little longer.
The more I wrench on this car, the easier it gets.
MFB
86 Targa 3.2, bone stock
Old 05-21-2004, 10:02 AM
ruf-porsche's Avatar
Wow
$32.50 for a new voltage regulator? Is it a Paris Rhoe?
Did they put it on for you or did you replace the old voltage regulator?
Name of shop/company that has the voltage regulator?
Old 05-21-2004, 02:44 PM
I'm not here.
K. Roman's Avatar
Yeah, it took me about 45 minutes to pull it out, to put it all back together was a lot more difficult. (1 1/2 hrs.)
Putting the white shroud around the alt. was so *&#$ hard until I just twisted the alt. counter clockwise about forty-five degrees. The other problem is getting the fan to be perfectly straight without it rubbing against the housing.
I ended up just driving it and grinding away some of the fan.
Oh well, it worked at least.
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 05-21-2004, 03:24 PM
See my similar R&R procedure for alternators in the Tech section of Pelican......
http://www.pelicanparts.com/techarticles/911_volt_reg_replace/911_volt_reg_replace.htm
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-22-2004, 06:24 AM
I flipped to a new regulator and will use the old Good one for a spare because I was in there. It'll go into the on-board spare parts smugglers box.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-22-2004, 06:38 AM
Originally posted by ruf-porsche
Wow
Yes, my alternator is a Valeo, and the new voltage regulator is Paris-Rhone, and they had it in stock. It's Pryor's Starters & Generators here in Richmond, Va. I dropped it off at 8:30, they tested, installed the new vr, and I picked it up at 4:30.
MFB
Old 05-22-2004, 11:33 AM
