Test Photo
Well look at that - great new feature Wayne
Opps it was meant to be in Wayne's thread !!
I think at this point we just say amen |
http://forums.pelicanparts.com/uploa...1085138358.jpg
So while I am at it - here's a photo of my recent 930 brake upgrade. |
Well David you have the turbo body, turbo brakes...when is the turbo engine coming? ;)
David.
Beautiful (nice car too). on-ramp. What's with the spaghetti? |
Let's Try This Again: Handy New BBS Upgrade - Help me test in this thread...
After hearing about people complain about not being able to resize and fit images so that they could be uploaded, I decided to incorporate a resizing routine into the website. Please help me test it.
The image upload feature should now allow you to post any JPG or GIF image of any size. It will reduce the size of the image on the server, and also constrain it to be 800 pixels wide or less (no biggie pics that crowd the screen). I made a change that should work for 99.9% of all images - you should no longer get an oversize message. For you techies out there, this is what the routine is doing: - Checks file size, and if greater than 100K, reduces dimensions to 800 wide. - If still greater than 800 wide, it reduces width to 640 wide. - If still greater than 100K - it then gives the 100K error message So only really super-tall images should trigger the error message. It also checks *all* images and reformats them down to 800 width max so that they won't screw up the page display. Let me know if this works any better. -Wayne |
Here's a test, starting with a 1.7M file.
Only took ~15 seconds to upload/convert. I like the results of this upgrade to the system. Tom http://forums.pelicanparts.com/uploa...1085167740.jpg |
Do you think this license plate is a bit pretentious? ;)
http://forums.pelicanparts.com/uploa...1085168446.jpg One runs 11's the other can turn.. guess which is which? ;) http://forums.pelicanparts.com/uploa...1085168571.jpg |
ouch! Another stripped bolt? I think a drill, easy out, and a torch will get that out of there. ;)
won't work for me....
testing, testing, 123...
Here's my test...
http://forums.pelicanparts.com/uploa...1085170828.jpg |
More tests, this is fun!!
Dr. Mark,
I've always liked this x-ray, taken after closure of the patient, of course. Tom http://forums.pelicanparts.com/uploa...1085172703.jpg And here's a classic...http://forums.pelicanparts.com/uploa...1085172714.jpg |
it's working, it's working, it's working!!! Big Fun!!
http://forums.pelicanparts.com/uploa...1085172651.jpg |
no P-car pics handy, but a classic:
http://forums.pelicanparts.com/uploa...1085173211.jpg took about 45s to up load on our T1 |
This picture is 3.2 mb. Had the pleasure of being at Macchu Picchu in the Andes mountains. Didn't see any Pcars on the mountain.
http://forums.pelicanparts.com/uploa...1085173875.jpg but here's one that I would have loved to see there. http://forums.pelicanparts.com/uploa...1085173962.jpg larry |
Works very fast for me but then again I have a cable modem.
http://forums.pelicanparts.com/uploa...1085174310.jpg http://forums.pelicanparts.com/uploa...1085174415.jpg |
Hey Wayne. Thanks. Much easier. Here is my VW/ Porsche.http://forums.pelicanparts.com/uploa...1085175346.jpg
Alan Poh '77 Carrera 3.0 '64 VW Cab/Porsche:D |
huge file , loaded fine
http://forums.pelicanparts.com/uploa...1085175215.jpg
3.5 turbo owned and built by John Simone / 355 rwhp by SUPERTEC |
Beautiful car Henry!
Easy load with new format
http://forums.pelicanparts.com/uploa...1085176091.jpg
Another 3.5 Turbo built by John Simone with SUPERTEC engine |
How fun is this?
http://forums.pelicanparts.com/uploa...1085177371.jpg http://forums.pelicanparts.com/uploa...1085177432.jpg
If you like what you see this is another RSR build by John Simone / 3.5 MFI engine 369 rwhp by SUPERTEC |
This is a Cool upgrade , Wayne
This is an experimental turbine racecar, I think from the 70's? http://forums.pelicanparts.com/uploa...1085178875.jpg http://forums.pelicanparts.com/uploa...1085178908.jpg |
http://forums.pelicanparts.com/uploa...1085181908.jpg
Worked from different computer, different network. Sure was slow though. |
Test
Test
Not applicable. -Wayne |
My Test...SmileWavyhttp://forums.pelicanparts.com/uploa...1085185340.jpg
| All times are GMT -8. The time now is 09:18 AM. |
