84 Carrera 3.2 emission time - no cat
Ok folks,
To avoid hauling the cat out of the attic and spending the afternoon on the swap of the fabby cat-by-pass...is it worth trying with no cat? I heard John Walker say to pull one of the injector connectors off and take the test that way. Seems alot easier. Any favorite injectors to disable to make my chances better? Car seems to run fairly clean although it is "Wonged" with his latest chip for the 3.2. Any bets that I can pass? -Jeff nolift911@hotmail.com 84 911 Carrera 01 BMW M5 LeMans Blue 04 Grand Cherokee Overland |
Where you live?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I ran my "wonged" no cat 3.2 through our testing and it passed with flying colors.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Can you find a place that will test it without a visual? If so, you might have a chance.
Cheers, Joe |
I live in VA.
The fabby cat by pass looks just like a cat...no way to tell. Your wonged 3.2 passed w/no disconnected injectors? This sounds promising... -Jeff |
Correct, I did connect the little brown "ca smog"wires beside the ECU and it also had the Fabby bypass at the time. Now the car has 964 cams and SSI's so that should be interesting!
Jeff
Green Skull 006
The last two times mine passed with flying colors. No cat, and I didn't disconnect anything. Good luck.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
Where in VA are you?
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
Has anyone tried this in CA. I am running a back dated exhaust with no cat and am wondering if I will need to spend the day relacing all the original equip? I kept everything and the place I go to doesn't even open the engine lid let alone crawl under but if it wont pass? then what happens? Also what if they do notice that you have changed thing in CA what can they do?
thanks steve
1982 SC |
I'll find out soon enough in November, Wonged with Euro pre-muff. Anyone out there with similar mods and passed in Cali?
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Lots of info at http://www.smogcheck.com. If your smog devices are intact, there is a relatively low limit of what you might have to pay to make the car pass. If you have tampered with or removed any of the smog equipment, there is no limit.
I think I will try just like normal and see what happens...can't hurt. -Jeff nolift911@hotmail.com |
I will send you a PM.
If you want to drive all the way to Alexandria, the Shell station on Franconia Rd. is Porsche-friendly. Shop owner's name is Sami and he drives a gorgeous 993 C2S. They probably won't do a visual there and if they do, they'll let you skate. There's no fudging the computer though. That stuff gets electronically sent directly to DMV right then and there. Mackpipes on this BBS talked about getting Autothority to burn him a cutsom chip specifically for VA's emissions inspection, since he has a Euro spec. Carrera with no cat. Check with him.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
