nigel911's Avatar
The squeak returns
Few weeks ago my car developed a very annoying squeak which seemed to emanate from the fan belt. Replaced the belt, squeak still there but a couple of days later the squeak stopped. Sorted, so I thought...
This week the squeak returned.
I removed the belts (AC & fan) and briefly ran the engine to see if it was the belts. Alas, it isn't. The squeak seems to be coming from the lower pulley area and increases/decreases with engine speed.
Ideas please - preferably inexpensive, quick to fix ones. Bet I don't get many of those...
Old 05-24-2004, 06:02 PM
Look for debris in the engine mount console (bracket around lower pulley). Jim
Old 05-24-2004, 06:13 PM
nigel911's Avatar
Seems clean but I will double check. Any other thoughts?
Old 05-25-2004, 05:59 AM
nigel911's Avatar
Anyone?
Old 05-25-2004, 01:14 PM
slater's Avatar
Could always do the quick sqiurr of wd-40. It wont last long, but sometimes it helps. sounds to me like the pully isn't perfectly straight. mine was a little warped and made a really annoying squeak
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 05-25-2004, 02:30 PM
nigel911's Avatar
Checked the mount bracket - all seems good, no debris to be found.
Slater, do you mean the lower pulley?
Old 05-25-2004, 03:33 PM
nigel911's Avatar
Beginning to think my problem is perhaps not 'technical' enough for the forum.
My last try at the cheap pool of knowledge, if not it's off to the ever appreciative, ever expensive P-CAR mechanic.
Old 05-25-2004, 06:24 PM
It's fustrating these squeeks.
My squeek stays away on colder days. On warm days and after fast turns it comes out to sing. I have not figured it out yet. Good luck with yours.
The area well below my lower pulley was full of gunk and grease. When I got degreaser in there I was able to fish out what looked like electrical connector wire covers. How they got there, I dont know.
I hope this is not your alternator, sounds expensive if it is.
Old 05-26-2004, 07:17 AM
