My jerry rigged brake cooling system actually worked...
Finally had a chance to test out my budget brake cooling system on the track yesterday. Happy to report that after 100miles of track driving, i experienced no fade. Ambient temps were about 60F.
Here is what i did. 1-Removed the factory dust shields 2-Installed Smart Racing Hub block off plates 3-Jerry Rigged the factory 993 air deflectors to fit my 88. 4-New Zimmerman cross drilled rotors all around Prior to doing this, i was experiencing significant fade at the track. Some pictures of the set up before i removed the dust shields...
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach Last edited by alf; 05-26-2004 at 07:02 PM.. |
Good to hear it.
double posted...
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach Last edited by alf; 05-26-2004 at 07:03 PM.. |
Cool
What did that cost?? For the deflectors and Smart racing parts I mean.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Looks like those deflectors could be cut out of sheet plastic pretty easy??
Night give it a wack!
Irrationally exuberant
What's with the stickers? That's extra weight man!
![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
eric!!!
remember, I have a vac forming machine at work!!! the stickers add more braking force... sjd
Porsche sold, moving back to muscle cars for a bit. |
Heres another neat and cheap way to cool your brakes like a pro:
![]() Just use the stocker dust shields and cut a big hole in it. Pair it up with some ducts from IOPort racing and you're set.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
Blockchain Tech Inventor
I thought stickers made cars go faster.
A Mean Green Lifted 1972 C10 Long live the king! Last edited by jrdavid68; 05-26-2004 at 10:32 PM.. |
Backing plates were $50 from Smart Racing, not sure if Pelican sell them. The 993 deflectors were under $40 from Porsche, they are reinforced in the back and have a scalloped design, probably difficult to duplicate from sheet plastic. Took about an hour or two to install.
The hose method would probably offer better cooling but was a little bit more involved. Would have gone that route if the 993 set up did not work. alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Stickers make one's 911 go faster only if they are on the outer sheetmetal.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Automotive Monomaniac
What's the Porsche part number on the deflectors (I assume there is a LEFT and RIGHT)?
Are there deflectors for the rear too?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
I just went to the local Porsche dealer and asked for the 993 brake air deflectors. I'll see if i could find the reciept, the sticker is no longer legible. Yup, left and right. No deflectors for the rear.
alf
How do you keep them from spinning around on the suspension arm?
I think these are the part numbers (I found them on an NSX site - they use them in the aftermarket for brake cooling too!):
"The parts in question are Porsche #993-341-083-00 (left) and 993-341-084-00 (right)."
No drilling. There is a horizontal rib in the back of the deflectors that will rest on the A-arm. Just zip tie it tightly and off you go. Be sure to remove the factory dust covers though.
alf
dave 1973,5 |
brake stickers make cars slow down better... sjd
What do the Smart Racing hub block off plates look like? Do they have a website?
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
