-   -   Expert needed - gap between body pannels (http://forums.pelicanparts.com/porsche-911-technical-forum/165008-expert-needed-gap-between-body-pannels.html)
doozer 05-27-2004 09:00 AM
I am putting the body back together -
What is the ideal gap between body panels -
Lids to fenders:
Fenders to doors:
Thanks!!!
RickM 05-27-2004 09:10 AM
I don't have access to my car to check but I would imagine there is an acceptable range for gap. Before tightening I'd eyeball the gaps for overall acceptability.
Since they make a tool for this very purpose I'd suppose you can quickly fabricate some fitment "jigs" out of wood. Panel Gapper ===> http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=1683&itemType=PRODUCT&RS=1&k eyword=gap
doozer 05-27-2004 09:38 AM
Anyone have the OEM allowed fitment specs???
project935 05-27-2004 10:19 AM
While watching the Barrett-Jackson auto search, I think Jackson said that Porsche gaps are supposed to be 3mm - he had a little nylon stick-gage he was using to run around all the gaps.
doozer 05-27-2004 10:26 AM
Ahhhhh!
3mm Anyone second that answer?
If so I am off to build my 3mm body gap gauge.....
Thanks project935!
no substitute 05-27-2004 11:19 AM
Go for it, use the hot rodder's standard, a dime (actually, Porsche may have a different standard).
RickM 05-27-2004 11:20 AM
If a dime is the standard I'm way off.
TerryBPP 05-27-2004 11:25 AM
They say to use a paint stick. I'd say thats pretty close to 3mm.
doozer 05-27-2004 12:08 PM
Thanks Guys!
Paint sticks and clear duck tape!!
techweenie 05-27-2004 12:32 PM
I've always heard 3.5mm.
RickM 05-27-2004 12:37 PM
If you look at the US based gap gauge and convert over to metric you'll get .79 mm, 1.5 mm and 3.1 mm.
So my guess would be around 3mm. Or in the 3 to 3.5 mm range.... :D
Wil Ferch 05-28-2004 07:21 AM
Depends on the car.....928 and the "Audi" 944 use much wider gaps....
--Wil
RickM 05-28-2004 07:25 AM
I suspect because of the "hand made" aspect of the 911 the gap is going to vary between individual cars.
Wil Ferch 05-28-2004 07:34 AM
Groan....this aspect is not very "hand-made"......the only exception being the silver/lead filler used ( by hand) on the 911 door's front/top edge....the rest is all body dies....pretty precise, too!
---Wil
RickM 05-28-2004 07:42 AM
The apsect I'm talking about is the panel fitment. Not construction. LOL
stormin48061 05-28-2004 07:44 AM
wow you guys are perfectiionist!! as long as the gap looks consistent all the way around, that's the right gap! nobody is going to say nice gap standing 10 feet away admiring your car..what they will notice is if the gap is equal to the eye!! have fun drive it! my $0.02
Zeke 05-28-2004 07:57 AM
All true unless the gap is 1/4" (little less than 6mm). I've been doing a lot of body work lately and when the gap is pushing 4mm, it starts to have "gaposes."
Wil Ferch 05-28-2004 10:09 AM
yeah...like Saturns and 928's..... !!
--Wil
doozer 05-28-2004 11:09 AM
I saw on one show where they filled the gap completely with filler, let it harden, and then went back and cut the correct size (small) gap - I think it was on an old corvette. Is this acceptable to do? Would you use body filler or fiberglass ( on a fiberglass panel)
doozer 05-28-2004 12:31 PM
Found this. (not Porsche but good info)
http://www.carcraft.com/howto/51979/
