-   -   How to build a Slant Nose Turbo Look 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/165052-how-build-slant-nose-turbo-look-911-a.html)
Kemo 06-08-2004 07:54 AM
Originally posted by rick-l
Sunset Fun -- did you guys take the day off?
yeah! i been following this thread with anticipation *drools*
cant wait for the next round of pics...
kepperly 06-08-2004 08:37 AM
WERK I,
Thanks for that bit of info, I was wondering if that was the
reason for the differance. I did my Carrera as close to the "later"
factory style with a Mocal cooler and aftermarket fan. Certainly
made the plumbing relatively easier. And I like the look of the
factory steel valance better.
Keith Epperly-87 slant nose turbo look carrera cabriolet
Victor 06-14-2004 06:58 PM
Feeling better yet? Maybe he should lay off the cigars....
kepperly 06-17-2004 01:34 PM
bump, need more info, more photos
RickM 06-17-2004 02:35 PM
That tail rubber is not happy.
Kemo 06-17-2004 02:51 PM
nice...progress...love it.
Victor 06-17-2004 03:24 PM
Any pics of the tuna? Hope he didn't put the cigar down during the fight!
k9handler 06-17-2004 08:42 PM
good to see you guys back in action.
Matt Smith 06-17-2004 09:51 PM
Savagery to tuna as well as tin. Will it never end?
Please end that poor 911's suffering.
rlh930 06-17-2004 10:18 PM
I remember, back in the day, when those turbo-look slant-noses were really cool. Well, it's only a Targa!
Adam 06-17-2004 10:46 PM
Thanks for keeping us in the loop on this project. I've been watching with interest!
Ray 911s 06-18-2004 06:23 AM
Glad you are back! And thanks for the thread.
Kurt B 06-18-2004 08:17 AM
A post like this can't be beat! Unfortunately, it looks very easy in the pictures, but I would be nuts for trying (and wouldn't). Very cool post! This is one for the archives.
Kurt B 06-18-2004 08:19 AM
Someone explain "peel and weld"
Emission 06-18-2004 03:15 PM
I am pretty naive about bodywork.
After the peel and weld, do you use filler (Bondo?) to fill the gap? What happens next?
RickM 06-18-2004 03:42 PM
Emission,
There are a couple of different, yet similar, techniques for doing this.
To answer your question, while you "trace cut" there will be a gap between the new flare and the existing body panel, in this case the upper quarter panel. As you progress this gap is spot welded, an inch or two apart, to hold the new flare in place. When the entire flare is spot welded in place you can remove the old flare from within the wheel well.
The spaces between the spot welds can then be connected using the butt welding technique. This is typically done on an alternatining basis to prevent heat build up in a small area which will create warping.
Hope this isn't confusing.
Porschekid962 06-18-2004 03:47 PM
jeeze is there enough Bondo on the welded on fender??? looks like a lot. interesting, i have never seen this done before, very cool its being put up for show and tell.
Emission 06-18-2004 04:33 PM
Originally posted by RickM
Emission,
...then you grind of the bead from the weld and smooth the metal down... right?
Very nice, and it's 100% steel. Cool.
89turbocabmike 06-18-2004 05:06 PM
Sunset, I sort of familiar with the concept of shrinking, but what would be the result of not"wet ragging" it? Does shrinking smooth the surface more or is it a stress-relieving measure? Thanks for the effort in posting this project!
Sunset Fun 06-21-2004 09:01 AM
The use of Heat and a Wet rag are to shink the metal. After using the Hammer and dolly to shape the metal. It is not necessary to Heat and hit with the Wet Rag.
You can use filler to get the surface smooth, We like to use as little filler as possible that why we use the Heat and wet rag to shink the metal.
