adamred's Avatar
Simple Green on the fan
Quick question:
I've heard that simple green's not the best for an aluminum motor. True?
Can I use it to clean some gunk and oil off of the engine fan while the fan is still installed?
Adam
Adam,
2019 BMW 540i
Old 05-29-2004, 09:07 AM
Semper drive!
rcecale's Avatar
Adam,
Not sure about Simple Green on aluminum, but I do know we were NOT authorized to use it on military aircraft. I think that was more of an issue with damaging the acrylic used in the canopies and windscreens though.
I'd recommend Greased Lightning - Auto and Shop. Worked like a champ on all my engine components when I had it out, including the fan. Just sprayed it on and worked it with a plastic detailing brush...cuts right through all the grease.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-29-2004, 11:40 AM
GrindingGears's Avatar
the fan is magnesium FYI
83 SC (gone) // 72 T (gone)
Old 05-29-2004, 12:11 PM
David's Avatar
I've had success with wheel cleaner. Some of the cleaners like automotive grade simple green will corrode aluminum and give it a whitish film.
Old 05-29-2004, 12:41 PM
Now in 993 land ...
aigel's Avatar
Any engine degreaser you can buy in the can will do too. You can even spray it off after use. The water will go the way the air usually does.
George
81 SC (sold)
Old 05-29-2004, 12:44 PM
Zeke's Avatar
Greased Lightening seems to have acid in it. I can't prove that, but the stuff is strong. I trust Simple Green, but it is hard on my lungs. I use it outdoors only. It has always kept my engines clean. I follow it with Tide.
Old 05-29-2004, 12:54 PM
Semper drive!
rcecale's Avatar
Acid? Can you elaborate on that a bit, Zeke?
One Marine's View
Old 05-29-2004, 01:32 PM
Someone posted the link earlier that was to a military test which indicated Simple Green could erode aluminum if left on for some time. I think the conclusion was that if you rinsed it off completely it was okay to use. Someone with a better memory than mine may have the link.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-29-2004, 02:11 PM
