Member 911 Anonymous
Hey all, look at what Santa Pelican Rnln brought me to save my old back
![]() ![]() Will use the heck out of it
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
hope you like it. I have mine for days and have not have time to install it. maybe i should do it right now.
Fat butt 911, 1987 |
LOL, do it now or you will never do it.
done. haha. Feel like to replace my oil level sender soon.
OSLU? Heck, let's service it first, I will show you how. Seat will come in handy
Harbor Freight carries a small/cheap rolling stool with a shelf underneath it. I keep one in the garage and one in the hangar. My old back thanks me EVERY time I use it!
1984 Targa |
Diss Member
I've had a couple fail on me. Last sender worked for less then a year so I have been ignoring it for years. When the first replacement failed I tried messing with it and never got it to "send" so just did a 'to hell with it'.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
, Rnln???
I have 2 of the HF style in my garage and find that they work just fine for soooo much !
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Draco, Wane,
An oil sender party sounds good. If you want beer, I'll have something to go well with it. Must be a while after Christmas for me to clean up my garage. Right now, it's hard to even walk in there. Wayne, long time no talk. My sender keep going bad one after another, make me feel like there might be an electrical short somewhere. Current one goes bad intermediately. It was bad for several months. I just drove it once last week, and twice this week. It's been working well. Somehow my car drives better in cold weather. Maybe I should trace the wire to see if anything looks suspicious. Guys, about the stool, how about sears stool at the price of harbor freight? I rarely go shopping so I grapped several of them on thanks Giving.
Fat butt 911, 1987 Last edited by rnln; 12-07-2012 at 12:38 AM.. |
Wait, do you mean the oil pressure sender aka Druck???
yes, the pressure sender, not level sender. Sorry.
Diss Member
When the pressure senders went bad did you test them with a multimeter after removal? Are they failing to an 'open'? (Does the gauge peg to the top of the scale?)
It is just too weird that you would eat a number of them. The one failure I can think of that would look like a repeated failure is if the wire, right at the sender, has corroded up inside the insulation or at cracks in the insulation. I've seen the wire fail such that when you bend it (as if you were replacing the sender) it would start working again. The fix was to clip off about 6" of wire where it was obviously hardened and splice on new.
Wayne,
I didn't test them with the multimeter. The gauge didn't peck to the max, but almost max. The connect wasn't bad. It's the senders were bad, because every time the new sender went in, it works fine for a while. I suspect the wire is short somewhere intermediately that damage the sender internal slowly. Just a guess.
