1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Need someone to identify this
What is this, what does it do, and what hose goes to that nipple on the front of it?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 05-30-2004, 01:16 PM
fred cook's Avatar
Cool Mystery port....
There should be a hose that runs from the cannister in front of the oil filter to the right side of the air box. It is a special hose with different size ends. It is part of the emissions control system.
Fred Cook
'80 911SC coupe
Old 05-30-2004, 03:23 PM
makaio's Avatar
Charcoal canister for the vapor recovery of fuel and fumes.
Old 05-30-2004, 03:51 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Good thing you posted a pic. I thought for a second you were talking about your avatar, had me worried there.
What Makaio said, charcoal canister.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 05-30-2004, 06:31 PM
1fastredsc's Avatar
Good one.
Anyhow, i've never heard of a charcoal canister, i have no idea what it does, and i don't have ac, heat, or emission control in the car. Should i just leave that nipple alone? Plug it? What about the lines that go to the back of it?
2007 Mazda 3 hatch
Old 05-30-2004, 07:29 PM
The charcoal canister absorbs fumes vented from the gas tank and fuel system , mostly when parked. It is normally purged with fresh air when the car is running . They are fairly lightweight and have little effect on performance one way or another. I would probably leave it unless you are fanatically lightening the car.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 05-30-2004, 07:42 PM
maxnine11's Avatar
diagram:
max
Old 05-30-2004, 09:31 PM
Air Medal or two
afterburn 549's Avatar
you can only run epa certified colored charcoal in the early models do to the 1970's clean air act .....so sad
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-30-2004, 11:01 PM
tholyoak's Avatar
The charcoal canister bung was left open to atmosphere on the later cars like yours, and the hole on the airbox plugged with a rubber plug (hose 6 in the above diagram removed) so as long as your airbox has the plug your car is as it is supposed to be. Leave it installed it isn't removing any performance and is helping the environment a little bit.
Todd
1989 911 Targa
Old 05-31-2004, 06:02 AM
1fastredsc's Avatar
Ok, i'm not that much of a freak to lighten the car, i was just hoping it didn't have any crucial vacuum going to it. Anyhow, i think you mean hose 5 was removed, because hose six i believe exits the back of the canister, around the front of the engine bay, to the left side of the air box. The hole that is plugged on my air box is on the right side facing the canister. Thanks for the information guys.
2007 Mazda 3 hatch
Old 05-31-2004, 01:42 PM
