-   -   Proper propane fill procedure on AC (http://forums.pelicanparts.com/porsche-911-technical-forum/165899-proper-propane-fill-procedure-ac.html)
Ed Bighi 06-02-2004 11:39 AM
All right guys, whoever out there knows all the tips and tricks to using Propane or Propane/Isobutane properly, please come forward and enlighten us. What is the proper way to put it in. The proper way to modify the nozles on the bottles (pics), the best ratios, the proper way to fill it, etc... For example, upside down or right side up (liquid/gas), and other things like that. Also, if there are any modifications that need to be made to the expansion valve, what needs to be done so that the evaporator core does not freeze up. Basically, if anybody out there has plenty of experience in this area, please give some pointers.
Wayne 962 06-02-2004 11:40 AM
Aren't there plenty of better (non-flammable) alternatives out there?
-Wayne
RickM 06-02-2004 11:42 AM
Ed,
Steve W uses a Propane cocktail.... http://forums.pelicanparts.com/showthread.php?s=&threadid=76715&highlight=propane +and+a%2Fc
Seems many of the alternatives are flammable. Including the popular Duracool.
singpilot 06-02-2004 12:00 PM
Most of the people that use propane or butane are in Tijuana or dead.
Emission 06-02-2004 12:02 PM
Is my "Freeze 12" fill flammable?
Ed Bighi 06-02-2004 12:04 PM
Actually Wayne, after much research, I have come to the realization that there aren't. Especially when one is trying to do the right thing for the environment. Not to mention staying cool. And for those that doubt the safety of the whole enterprise, go here www.greenchill.org. Look up the scientifical studies done on it. Very safe indeed. Though over here in the US, where fear is a hobby and dupont has influence, there is plenty of BS going around. While it can be considered dangerous in a theory, in practice it has been extremely safe. And for those that don't know, R134 is flamable under compression.
Rot 911 06-02-2004 12:09 PM
I don't know why it would be anymore dangerous than pressurized gasoline in rubber fuel lines.
Steve W 06-02-2004 12:10 PM
More than you ever wanted to know:
http://www.vettenet.org/acfaq.txt
Ed Bighi 06-02-2004 12:19 PM
Steve, I read that thing already. I need what that does not say. Like do you put the propane as a liquid or a gas. Invert the can or not. How has it affected the expansion valve? Do you need to tweak it to cope with the super low temperatures? Basically what I am looking for is how this applies to our cars. Oh, and how are your results?
Steve W 06-02-2004 12:34 PM
Ed, my system works b*tchin. Gas or liquid, I don't think it mattered too much in my case. I screwed an ac hose adapter to the end of a propane torch tip with a pretty small hole drilled at the tip, and I think I put it in upside down as a liquid. Just don't flood it in as a liquid too fast. Also be aware that by weight, if a system normally takes 36 oz of r12, you only install about 14oz, (don't remember the exact weight conversion) of a propane/isobutane mix.
I drilled a very small hole out of the propane torch tip to open it up. A standard propane tip hole is smaller than a strand of hair, and I didn't want to wait two hours for the thing to empty. I also drilled out the check valve on the underside of the torch adapter. I removed the screw on flame shroud at the end of the torch, and retreaded the end to match the threads on my ac hose. I screwed one end of the hose onto the end of the rethreaded torch, and screwed the other end onto the low side ac valve. Turn on the torch valve to release the gas into the system.
For isobutane, use about 20% by weight, and I used MSR's brand from Sport Chalet here. It is about 80% isobutane and 20% propane. The top of the can is pretty much identical to the tops of old R12 cans, so my old R12 ac adapter worked fine.
Check the high and low system pressures after you are done to optimize.
Ed Bighi 06-02-2004 12:41 PM
What pressures should I be chasing on the high and low side? They are probably going to be lower I presume. Probably lower than R12 and a heck of a lot lower than the usual 134 numbers. I gotta go find an old R12 hose. Somebody is gotta have one.
Steve W 06-02-2004 12:47 PM
I don't really remember as I did this quite a while ago. It should be similar to R12 if you use a 80/20 mix. If I recall, on my truck, it worked well at around 210/35 high/low.
Ed Bighi 06-02-2004 12:51 PM
Sounds normal Steve. Are you having any problems with the evap core freezing up?
RickM 06-02-2004 01:31 PM
BTW, at the bottom of this link page is a chart of the EPA accepted and unaccepted refrigerants. Notice some of the ingriedients.
http://www.epa.gov/ozone/snap/refrigerants/macssubs.html#note5
Steve W 06-02-2004 01:48 PM
No, the evaporator themostat should be taking care of modulating that.
banjomike 06-02-2004 02:16 PM
Start by lighting up a cigarette...
[skip several steps]
have your wife call 911
or just ignore my advise altogether!
Wayne 962 06-02-2004 02:37 PM
Hmm, gasoline is a liquid at room temp, propane is a gas.
Admittedly, I am not a cooling system expert by any means...
Are there any DIY articles out there for AC conversions?
-Wayne
Ed Bighi 06-02-2004 02:40 PM
Originally posted by RickM
[B]BTW, at the bottom of this link page is a chart of the EPA accepted and unaccepted refrigerants. Notice some of the ingriedients.
Rick, there are some very weird things about the Eternal Pain in the Ass (EPA) and the way they look at refrigerants. For instance, why do they require R134, which by their own account, does not affect the ozone layer, to be recaptured? After all, it's supposed to be safe for us right. Besides, all it causes is testicular cancer and who needs testicles? But at the same time, you can spray 134 freely all over your keyboard to dust it by using a canned duster. That's what's inside those after all. But you can't route a pipe from one of your R134 nozzles and route it to your keyboard. The truth of the matter is that in fact R134 is toxic. Much more so than, say, propane. After all, would you cook with something highly toxic? But don't listen to me. Go dig up your own dirt on R134 which is far from a perfect solution to R12 in not just reduction of pollutants, but in cooling as well. Besides, the only issue with propane is flamability, which is also present in R134. Now that would be the concern of the DOT, and not the EPA. So why is the EPA sticking their nose where it does not belong. After all, all they are supposed to do is to look after pollution issues. Maybe because Dupon't likes it that way and lobbies hard. Or maybe because the MVAC repair industry does not like the difficulty of capturing many different elements? Not to mention losing some potential business. After all, I only started paying for AC service when R12 stopped being sold to non-licensees. Never mind the fact that there is no pollution problem from venting propane, or LPG which are naturally occuring substances, like farts. Bottom line, I stopped listening to the EPA a long time ago. Especially when Europe and Oceania, are head deep in phasing out CFC's, including R134, and going towards HC's for refrigeration. Even Greenpeace supports the use of Propane for refrigeration. R134 will not be around for as long as people think. Not only for pollution and toxicity issues, but for performance issues as well. But the hell with it as far as I am concerned. Last time I checked, propane isn't a controlled substance and for good reason. After all, the DOT lets us buy it, put it in our trunks, and drive with it. And if it finds my way into some pipe in my car, oh well. After all, neither is alcohol supposed to find its way into our own pipes when we drive, but who is following those rules. Neither am I supposed to speed for that matter.
Steve, the reason I mentioned the evap freezing up, is that propane seems to cool too good and some people end up with outrageously low vent temps until the thing freezes up. But I guess that with the limited size of the condensder in the 911, that won't be a problem. I guess I have to try. I should probably clean the condenser anyway.
Elombard 06-02-2004 02:48 PM
fascinating - keep us posted. What about using the Freeze 12? Would that be an easier fill??
RickM 06-02-2004 02:51 PM
Ed, You make many excellent points. At the end it depends on who's lobbying who the hardest.
As mentioned before just about every R12 alternative (if not all) is flammable.
RickM 06-02-2004 02:58 PM
I guess to the point here is cost and availabilty. Propane is surely cheaper and MUCH easier to obtain than anything else. Seems the "fill" instructions for propane are pretty much the same as other refrigerants. (other than amount and pressure)
BTW, Freeze 12 is non flammable and EPA accepted BUT it requires a certification to purchase and is relatively expensive.
Elombard 06-02-2004 02:59 PM
I see I thought the freeze 12 was cheap and no license, I must be thinking of the Duracool.
Ed Bighi 06-02-2004 03:01 PM
Elombard, Freeze 12 is basically 80% R134 with 20%R142B mixed in. The additives are there to make it work on a R12 system I think. I am not crazy about it. It is nowhere near as light on the compressor as HC's are. There is someone on this board, named Fox I believe, who sells Duracool. Maybe he will step forward. Now Duracool, Enviro-Safe, or Hychill which is the leader in Australia, are all HC mixes. Basically Propane/Isobutane in varying percentages. Anywhere from 50%Isobutane/50%Propane to 40%Isobutane/60%Propane. Propane is what does the cooling. The Isobutane is there to help in oil movement and to lower head pressures. Besides, you would get maybe too much cooling with pure propane. The common practice is to put in one of the mixes and then boost it with extra propane for much better cooling. At least as good as R12 from what people say. Far better than R134. Probably the best percentage from the passenger standpoint is 20%Isobutane and 80%Propane. At least from what I have heard. There is also another product out there called Autofrost. That one is a little different. It has common R22 as the main gas, with something ese, I don't know what, to bring it down to acceptable head pressures for car compressors. I also heard that these propane/isobutane mixes tend to leak less. Who knows. Or who cares since it's so cheap.
JRISER 06-02-2004 03:19 PM
Most coolants are flammable. I would go with Duracool. I will be converting my system to this, and I have heard that it is more efficient that R12 and cheaper too!
Elombard 06-02-2004 03:21 PM
Good stuff - this is the way I am planning on going if I add the AC back on mine. Duracool advertises in some of the P car mags, they could probably help with your questions??
RickM 06-02-2004 03:23 PM
Ed,
I assume you'll be purging your system when/if you go to the Propane mix. If not the existing R12 will throw your calculations off. Also, which lubricant will you use? Synthetic?
RickM 06-02-2004 03:26 PM
Remember, Duracool (or whatever it's called now) is not EPA approved and is flammable. Mixing any other substance with R12 (or R134) is illegal.
End of Public Safety announcement.
Ed Bighi 06-02-2004 03:27 PM
If I am making a good point, it is so because I am not just spewing some opinion off the top of my head without any real resarch into the matter at hand. After all, an opinion should always be a reasoned judgement based on facts, not fiction. As to who is lobbying the hardest, or who is lobbying for that matter, it seems just about everybody. But never has it been more clearly evident as it is with the EPA's stance on refrigerants. The BS on this one reeks like it never has before. Again, all one has to do is to ask why the EPA does not allow the venting on what is supposedly a truly safe refrigerant. This question has many ramifications. And at the same time, why the EPA, an agency only in charge of POLLUTION issues, does not allow the use of a substance that is clean enough to cook with. Flamability? Since when has the EPA been in charge of making sure your car does not catch fire. That is the DOT's or the NHTSB's job. After all, was it the EPA that went after the Pinto? Strange protectionism, I mean, politics folks.:rolleyes: But on this matter, the BS is as clear as glass.
I just wish we could mature beyond this point and get to the issue at hand, which is how to use it. It's like trying to have a converasation about radar detectors, which gets sidetracked by someone arguing about the illegality of speeding. We should leave the political issues to the OT board, and get back to the technical over here.
turbo6bar 06-02-2004 03:39 PM
Regarding the non-approved status of HC for R-12 retrofits, I believe it is legal to use HC IF you retrofit your R-12 to R-134a. Then, you can legally (according to EPA) convert to HC refrigerant. Of course, this is just lunacy.
Regarding using 100% propane, it will work as long as your evaporator doesn't freeze. I retrofitted a diesel Mercedes with straight propane, and vent temps get down to 20 degrees, while the evaporator freezes. In the early Mercedes design, the compressor is always on, and the fan speed is variably adjusted. If you have a temp switch on the evaporator (to turn off the compressor when vent temps reach 30 degrees), then you can run propane. However, I'm worried about this issue with oil transport via propane. Wouldn't you want the oil to be in the compressor all the time?
I recently read a ASE article that compared r134 to the substitutes. Propane was about 10% more efficient than R134a, with the primary/only drawback being the flammability of propane. To avert this issue, the article suggests a double loop system in which an external evaporator cools a liquid, like water. The water is then pumped into the passenger compartment where it passes a second heat exchanger, cooling the cabin air.
I do feel there is risk with running propane, but that risk is very small. What are the chances a crash creates a leak in the evaporator only (filling the cabin), while not breaking any windows or creating any air leaks that will vent the gas? I'm not saying it could never happen, but if we are looking for zero risk, we might need to consider never stepping in the car in the first place.
Lastly, and sorry for rambling, HC refrigerants are used in the petroleum industry (for chillers I believe), and in residential refrigerator compressors. If this stuff was so dangerous, I think we would hear about it.
jürgen
david914 06-02-2004 03:45 PM
DITTO! :mad:
Ed Bighi 06-02-2004 03:48 PM
Australia spent millions upon millions testing it. Including crashes. The end result being no exposions. The reason being twofold. First the tiny ammounts in the system, which is less than a coffeee mugfull. And second how quickly it escapes from the system.
I think the Isobutane has a dual purpose. To help carry the oil and to reduce the head pressures. I read somewhere that full propane fill is somewhat close to a full r22 fill. With the isobutane, it becomes more like r12. But with lower head pressures on the compressors. All still very compressor friendly. Turbo, how did the compressor hold on full propane. I ask because with full propane, it should cool like crazy.
I am leaving right now to get a tapping kit for the nozzle. Along with a r12 hose. Hopefully I can find one. I'll be back in a couple of hours and see what I can come up with.
singpilot 06-02-2004 03:55 PM
Me being the guy that doesn't like to make waves, always thinks of the repercussions of travelling a lot (which I do) and having some work done (even a 'simple' recharge, which these days is a evac and recharge) and the mech doing the work having his equiptment contaminated by whatever mix of gases is in my system. If I tell him ahead of time, he (rightfully) is not going to touch my system. How about when you sell the car? Are you going to disclose it? Me neither, I guess.
I'll stick with the OTC stuff. My stock system works fine across the Mojave Desert for the last 4 years.
turbo6bar 06-02-2004 04:16 PM
OK, so I probably need to get some of this Isobutane/Propane camp fuel. With propane, charged by weight, the pressures are mighty high. However, once you get some airflow across the condenser, the pressures come down pretty good.
The compressor is a brand new unit. I can't even remember the brand. It's a popular Japanese unit. Nippondenso, maybe. With propane, I think one could honestly get the cabin air temps down in the 50s, if desired. If cools like mad, AS long as you get airflow across the condenser. When in the driveway, I recall vent temps in the mid 40s. Once you got on the road, the temps steadily dropped, and with the auto evap fan control, the slower fan speeds = even colder evaporator temps. That's why you'd get low 20 temps when the car was cooled.
BTW, if you charge propane only, you can charge vapor or liquid (just don't slug the compressor), but if you charge a isobutane/propane blend, you need to charge by liquid due to differing vapor partial pressures. However, if you charge an entire can of the blend, you're gonna get all the mix out regardless.
good luck. I just need to do some refining to get perfection. I'm sold on the HC products.
Jurgen
Emission 06-02-2004 04:23 PM
What do the planes use on the ground in their A/C?
(I know they use ground units in some instances... but what does their APU turn for A/C?)
JRISER 06-02-2004 04:49 PM
The reason R134a is the standard is not because of its cooling properties. It is because the A/C manufacturers and automakers are "in bed" with the company that makes R134a. Funny, if Duracool is not EPA approved, why are there so many distributors in the US? And how come the military uses it? I'm not trying to sell everyone on Duracool, but I have read some pretty impressive statistics on this compound. I know, I know, don't believe everything you read... I am only giving them credit for half of what I've read! From the test results and pelican feedback that I've read, it is twice as efficient as R12, with R134a not even in the same room. The nice thing about this compound is that you do not need to switch compressor oil. You do, however, need to completely evacuate your system. You are not allowed to mix R134a or R12 with this compound. Also, you will need to put on the correct fittings on the discharge and suction connections.
Good luck!
JRISER 06-02-2004 04:53 PM
BTW, the Duracool conversion kit is $59, and that includes the coolant.
Ed Bighi 06-02-2004 05:24 PM
Actually, some folks have just thrown duracool over whatever remnants of freon were in the system and did all right.
Just picked up an R12 manifold gauge set with all the hoses and connectors. Now I have to figure out how to rig the hose on to the Benzomatic propane nozzle. Worse comes to worse, I'll just marine-tex the thing together. Or chop the end of the hose and slip and clamp it over the nozzle. Easy enough.
Lucky for me, my compressor is damn old. If it craps out, oh well. I could probably use a fresh one anyway.
JRISER 06-02-2004 05:46 PM
Ed:
Mixing the two is not adviseable, since Duracool contains some lubricating properties that are not compatible with other coolants.
BTW, be sure to take note of the difference in pressures of the two substances. The Duracool pressures will be lower than that of R12 or R134a; you certainly do not want to overfill the system (which will cause your system to not blow cold) and damage your compressor.
KobaltBlau 06-02-2004 05:55 PM
Why did this turn into "which refrigerant should we use to replace R12?" That was not the question.
I did my research and I came to the same conclusion as Ed. This is my own choice. I am also interested in fill procedures and not "hey look what the EPA says about that not being legal"
ACTUAL QUESTION:
If I have my local shop suck out my R12, can I charge with HC in the next few days without re-vacuuming, without losing effectiveness? I ask because I would rather not buy a vacuum pump.
TIA for Technical Answers, but not Dogma.
singpilot 06-02-2004 06:01 PM
Most planes use air cycle machine for A/C. Somewhat inefficient unless you have lots of airflow. Which is something we have a lot of.
Some of the ground units do use a conventional freon-based system. The coolant used depends on it's age.
Very rare that an airplane uses a freon cooled system. Once airborne, the problem becomes keeping the incoming air warm enough.
Last week, I saw -77 degrees Centigrade at altitude. Minus 97F or so.
Sorry, didn't mean to become part of the 'dogma' crowd, but seems it went that way again.
