Senior Member
ohecht's Avatar
Muffler to SSI flanges?
Does anyone know a good source to find flanges that will fit onto the end of my SSIs as I build up a custom exhaust system?
The flange is a 2-bolt with a 1 7/8" ID opening.
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 06-06-2004, 03:37 PM
Bill Verburg's Avatar
I bought a set of ss flanges in the SSI pattern from B&B
The one on the right shows the result of not trimming the oem gaskets to the correct size
Bill Verburg
Old 06-06-2004, 06:03 PM
Senior Member
ohecht's Avatar
Thanks, Bill. I will talk to them.
Is the gasket difference you are talking about between the SSIs and the B&B flanges?
I could not find the right OEM gasket on Pelican.
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 06-06-2004, 06:22 PM
