yama1's Avatar
Question While it's gutted any suggestions?
I have gutted the old brown and am replacing with black, Is there any additional things I should look at or do prior to the carpet set install.
US spec - not lowered yet
85 Euro 911 carrera
77 911 widebody coupe
"Drive the Ride"
Old 06-05-2004, 07:16 PM
I'm not trying to be a dick, but what happened to your door?
CConnor
73E targa
89 Coupe
Old 06-05-2004, 08:49 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
For the best bond between the new carpet and the interior you have to remove all that old glue. Yellowish orange in color, that way when you spray the new glue it will bond well and wont lift. I used lacquer thinner, fans for ventilation and a respirator, lots of scrapers and time. If you dont want to remove the sound deadening at leas lift it up and check for moisture and rust. From your pics it looks like most of the sound deading is gone, cant tell though. Look everywhere for rust after you clean all the glue off. Check over and over again, get rid of any moisture, rust kills. Car looks very nice though, hope you didnt buy the heavy carpet, haha.
74 911s neverending story. two feet and a jetta for now.
Old 06-05-2004, 10:52 PM
You do not have permissi
john70t's Avatar
It looks like you've taken it down to the metal in several places.
Now would be the time to get rid of all the rust and seal it up with a good epoxy paint or POR15 just to mak sure.
My 70 had hidden surface rust starting underneath the floor tar which was scraped up and replaced with new tar strips followed by paintable undercoating (the non-drying type was a mess) Nice job so far.
Old 06-06-2004, 07:52 AM
a few lbs of Dynamat will quiet some street and tranny noise.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-06-2004, 08:19 AM
yama1's Avatar
I didn't even plan on taken the old glue off, I would have probably just gone over, but I will remove. I have already chipped away at the floor tar and found some surface rust in areas. I guess that means I should lift the rear sound tar as well. It's got cracks here and there anyway.
CConor - The picture makes the right door look worse than it really is. The grocery store saga (idiots) and it's not quite right. Eventhough matching color code.
thanks guys
85 Euro 911 carrera
"Drive the Ride"
Old 06-06-2004, 06:38 PM
