ed bates's Avatar
Windows slow and front vibration
When I recently test drove the car I am purchasing, the windows went down and up rather slow. I don't think this is normal speed. Does this indicate the motors are going or what? I find it odd both are failing at the same time.
As when I got to 40 mph there was a small vibration on the drive. The seller said the front tires need to be balanced, which sounds true...and the front tires are running a little low on tread. Any opinions on this?
Thanks,
Ed
1979 911SC (The only way to fly)
1999 740I BMW
2002 SLK320 MB
95 Surb w/26 Hallett Sportboat
Old 06-07-2004, 04:02 PM
david914's Avatar
Window motors might be OK. Most likely you'll need to remove the window assemblies, then clean and lube everything back up. It makes a world of difference.
As far as the vibrations goes, the tires could definitely cause that. The only way to be sure is to have it checked out. Again, probably a non-issue.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 06-07-2004, 04:22 PM
