-   -   3.2 L Dyno Results *gasp* (http://forums.pelicanparts.com/porsche-911-technical-forum/166806-3-2-l-dyno-results-gasp.html)
ZAMIRZ 06-08-2004 01:30 PM
that's a strong motor, congrats :)
edit: low blow wayne, low blow:D ;)
KobaltBlau 06-08-2004 01:31 PM
oh boy, wayne!
edit: but dane got a little more torque (could it be the .2 liters?) and he barely modified the motor compared to this 3.2 .... er ....
nostatic 06-08-2004 01:34 PM
Originally posted by Wayne at Pelican Parts
Hmm, 219 RWHP. Isn't that exactly what the CIS 3.4 got?
http://forums.pelicanparts.com/showthread.php?s=&threadid=166093&perpage=20&pagen umber=2
-Wayne
yeah, but the 3.4 cranked out a lot more torque.
Ho Hum 74 06-08-2004 01:38 PM
Those are great numbers out of the 3.2. However, the stock # of 198 hp puts the flywheel at 233 hp using your 15% drivetrain loss factor.
Now doesn't the stock motor put out something like 217? How do you explain the 16 hp difference? Or did you just have something special to begin with?
Tristan
KobaltBlau 06-08-2004 01:50 PM
Ok, first of all, it may not be OK to compare the dynos, for reasons hashed out over and over in other threads.
However, since we already are :p, I'll say this ... If you take the proportional increase in displacement from 3.2 to 3.4, this engine would scale from 195 tq to 207 tq. This means the 3.4 CIS has 6 lb-ft on what a theoretical scaled verson of this would have. not too much. Imagine what this motor would do with a 20/21 cam!
ChrisBennet 06-08-2004 01:53 PM
Lets not forget that factory engine figures are minimums.
-Chris
jpachard 06-08-2004 01:54 PM
Tristan, The previous # was with a B&B exhaust(198rwhp). Trust me that this engine is stock. This is on my Club Racing car and the scrutineers can pull a "full cavity search" on your motor if they suspect anything.
James
Ho Hum 74 06-08-2004 01:58 PM
James,
OK - completely understand. Those are great numbers - congrats. This is why my 74 Euro spec car probably won't be that competitive in E-Class.
Best of luck with this season.
Tristan
Jack Olsen 06-08-2004 02:00 PM
-Chris
Also keep in mind that no dyno operator or manufacturer has anything to gain by having their software put out conservative-skewing numbers. Some inflation is inevitable. Like a scale, though, they're useful for measuring the impact of a given mod, relative to a baseline run from the same motor, on the same machine (preferably on the same day).
The bottom line is that the Porsche 3.2 is no slouch, especially with an improved exhaust and chip.
dd74 06-08-2004 02:01 PM
-Wayne
When I looked at this thread a second time, all I saw was Amir saying "Low blow, Wayne," and I knew right off the bat Dempsey was up to some *****! :D
Hilarious, Wayne! I nearly coughed up my lunch, laughing!
James: A big ol' fat hairy congrats, man. That's good stuff. And you didn't have to cut into the motor to get it. Sure, torque wins races, but stock torque means you've saved enough money to still take your car to the track.
And you didn't spend $13K doing it, either. SmileWavy
Hmmm...maybe a 3.2 is the better deal...:)
juan ruiz 06-08-2004 02:03 PM
I only have one single question, :confused: where this 15% loss comes from? I have contacted Dyno Jet and other Dyno manufactors in search of this documented data, so if you guys have it please share with me as everyone seems to have a different %.
ken_xman 06-08-2004 02:09 PM
He must have added one of the propellers in the tailpipe.
Jack Olsen 06-08-2004 02:33 PM
Juan, no one believes 15% is accurate, especially over a wide range of cars and transmissions. But if it's used as an accepted figure, it at least stops the skewing of everyone's rear-wheel numbers in different directions.
Wheel horsepower figures are the most useful number, of course, but that leaves open the question of what the cars in stock configuration would have typically put out.
nostatic 06-08-2004 02:36 PM
James
come on...confess. How many eRams do you have in there?
rzepko6194 06-08-2004 02:42 PM
Originally posted by geof33
Well, it just a matter of time before that sooped up engine will be pinging and knocking all the way to the dead cylinder zone...:D
Loren, is that you? ;-)
MichiganMat 06-08-2004 02:56 PM
is the exhaust available to the public? is there a website someplace?
Wavey 06-08-2004 03:07 PM
(Sound of wind blowing across the empty desert, a tumbleweed drifts by...)
Voiceover: "Loren? Loren?"
MotoSook 06-08-2004 03:18 PM
Another low blow from David. Man I thought you liked your CIS :D
I wonder what it would take to make my engine into a DME controlled 3.2 then add chip, air cleaner and exhaust? Less than a 3.4 conversion? Or would anyone be willing to swap a 3.2 for my 3.0? Neither is likely to happen....and building a 3.4 CIS engine from a 3.2 CIS is likely to be a better option for the same power...but there are other complications..like class rules, for one.
Man is it getting hot in here theres days...must be the summer heat :D
rzepko6194 06-08-2004 03:37 PM
I'm sure he's busy constructing an intelligent and appropriate response. ;-)
dd74 06-08-2004 03:42 PM
I love my CIS.
I like this, too:
http://www.clewett.com/products/carrerasm.jpg
It's a 3.2 induction bolted to a 3.0. Clewett Engineering sells them. They're not cheap...
