magic930's Avatar
Question Crank Trigger position
Anybody out there with a crank trigger wheel on the pulley...
Could you tell me where the missing teeth are in relation to TDC and the sensor?
Old 06-19-2004, 07:43 AM
Matt-Man's Avatar
For standard timing, the sensor is aligned exactly at the trailing edge of the 11th tooth after the two missing teeth. This is done at TDC #1. You can download the complete instruction manual at Electromotive's website.
Matt
'73 911 Targa / 2.7 RS spec
Old 06-19-2004, 08:21 AM
