thor's Avatar
piston difference 2.0E and 2.0S
hello ,
do you have photos or sketches concerning 2.0E and 2.0S pistons ? I know the difference in the lower part (more longer ) but the 2.0E is it domed or not ? *
thanks
Old 06-16-2004, 05:52 AM
jluetjen's Avatar
This is per the factory shop manuals. Note that the E and L pistons are similar - the change in CR was 0.1.
It's interesting that the L pistons have the oil rings at the bottom of the piston.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-16-2004, 08:38 AM
thor's Avatar
thanks
yes it 's strange for the L piston !!!!
do you think the last sketch ( for a T piston ) is similar for a E piston ? it seems that mine are theses ones (domed with cut out for valves but not S one)
I want to be sure that my engine has not S piston . I have all the bill since 1969 but you know ..sometimes there is some surprise !!!
Old 06-17-2004, 12:23 AM
jluetjen's Avatar
Do you have your pistons out of the case or not? On the 2.0, all of the pistons appear to have valve reliefs. But I doubt that the E pistons would look like the T's since they would not have the E's CR nor the space around the valves to work with the E cams.
John
'69 911E
Old 06-17-2004, 04:09 AM
thor's Avatar
yes , I will try to put this weekend a photo online.
There is cut out for valves and they are domed .
Old 06-17-2004, 04:19 AM
