svonkampen's Avatar
When I hit my brakes the blinker speed slows down....
And if my headlights are also on they really slow down........
Will a new battery fix this?
Anyone else had this problem?
SvK
Old 06-16-2004, 11:49 PM
scottb's Avatar
I haven't had a similar problem, but I'd be willing to bet your alternator and/or regulator are shot. Put a volt meter on the alternator and check your readings when you turn on the lights, hit the brakes, etc.
1984 Targa
Old 06-17-2004, 01:01 AM
Bad earth is also a possibility. I saw a car that had no brake lights only when the engine was turning. Cleaning the earths solved the problem.
Old 06-17-2004, 01:51 AM
On a great circle route
xlr8's Avatar
How close do you drive to the speed of light?
Russ
Old 06-17-2004, 05:08 AM
project935's Avatar
You're low on blinker fluid
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 06-17-2004, 09:33 AM
Ray 911s's Avatar
Does the blinker indicator (arrow in the dash gage) also get dimmer when the blink rate slows? Or possibly both indicators glow dimly? You may have one blown brake lamp bulb. Do a walk around and check all the lights and have someone watch your brake lights for you.
Bad ground or blown bulb will both account for this symptom. Other things can also cause this symptom, but might as well start the diagnosis with the cheap items!
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 06-17-2004, 10:22 AM
There's a ground wire near the right rear tailight assembly that could cause this. As I recall, you'll need to remove the housing to access it.
Old 06-17-2004, 10:26 AM
MAS MAS is offline
Yeah... a bad earth/ground could easily be the problem. Most likely in or around one (or both) of the tail light assemblies. It's fairly easy to pull them apart and clean all of the contacts.
If it is the fan belt slipping, then the same thing would not happen at idle (or at least, I can't think why). Easy experiment, anyway.
PS... I had a similar problem... it was a bad ground in one of the tail light assemblies.
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 06-17-2004, 10:41 AM
KobaltBlau's Avatar
Dang, Russ. LOL. very funny!
Andy
Old 06-17-2004, 12:45 PM
