To Remove the A/C and Smog Pump or Not.
Well I just ordered a tune up kit and a bunch of stuff for my new ride. The car has been sitting for awhile and needs a major tune. Scooping out the engine compartment, it seems a little crampped, especially with the a/c compressor and the smog pump in there. I will never use the air, but will need the smog pump in 2 years when I have to smog it again. So my question is should I pull these out of the car when I do the tune up? How many of you still have your a/c compressor intach? I thought I could just remount the smog pump when its time to smog again? WIll this cause any problem to operate the car without the pump, any performance gain.....
Let me know your thoughts.! Thanks, Ed
1979 911SC (The only way to fly) 1999 740I BMW 2002 SLK320 MB 95 Surb w/26 Hallett Sportboat |
Now in 993 land ...
a/c is gone in mine. No need to keep that around. It's only heavy in a bad spot and always in the way.
I'd keep the smog pump all set up stock, I wouldn't want to prep the car for smog beyond a tuneup. George |
if the ac works keep it. the smog pump only gets in the way, other than that, it really doesnt do any harm. hell, even the ac compressor can be flipped out of the way. easy.
poof! gone |
Where is that wrench?
Try doing a search. There have been lots of threads on removing A/C, and smog pump.
Broke
If you remove you smog pump for two years then try and put it back on, it will likely be frozen and you'll have to buy a new one. And you know the smoggies will fail you if they get half a chance.
Beer is proof that God loves us and wants us to be happy. B. Franklin 93 968 Cab 81 SC Targa (Princess) Now Residing in Denmark 1973 RS Z28 Vash will never own it! |
disband
AC yes, smog pump why? it is not a HP bandit and until you become smog exempt ( if assembly bill AB2683 passes it will be never) it better be there, even in so cal
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
