battery - reverse hook up
what will happen if i hook up my battery in a reverse manner?
i've taken the battery out and when i to put it back in it doesn't seem right. I have a 92 911 C2, looking at the battey cables I would assume the one furthest from the front of the car is the positive and the closest is the negative but when i put the battery in the posts line up the other way. thanks for helping this idiot (me!) |
I definetely would not hook it up backwards. Delicate electrical devices generally do not like reverse current flow (reverse polarity). Some things will work OK, others will blow. I don't know for sure if all the Porsche components are the former or the latter, but it could be an expensive experiment. Maybe others on the board will know for sure.
"Igneous Aquam et Laudi semper" Carl Muckley |
Is it not possible in a '92 C2 to tell which of the battery cables goes to ground? It will, of course, be cable that is attached to some part of the chassis--the cable that in effect "dead-ends." That cable attaches to the negative post (marked with a - ) of the battery, and the other cable attaches to the positive post (marked with a + ). Definitely do not hook up the battery backward, even just as an experiment. You will do considerable electrical-system damage.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Location: member Central PA Region PCA , Home of the Hershey Swap
DO NOT hook up your battery with reverse polarity.
Your car should have one red cable and one black. Red is positive, Black is negative. The 2 battery poles are usually different sizes too. The positive pole is marked with a (+) and the neg. (-). The ground cable connects to the car body. Also use anti-corrosion battery preps, available at your local automitive store. regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue Last edited by rbcsaver; 06-19-2004 at 06:12 AM.. |
STOP!!! Don't assume anything! If you connect the battery backwards you're likely to do all sorts of damage to your car's electronics, particularly if you turn the ignition key on. The negative cable should be fairly easy to identify. It should be bolted directly to the car's chassis close to the battery. If you can't find it that way, use a meter to check for continuity from each cable to a known ground on the chassis. The cable that shows the lowest ohm reading will be your negative.
P.S. Besides, if you connect the battery up backwards, your engine will turn the wrong way and you'll wind up with 1 forward gear and 5 reverse! (just kidding, of course)
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
"Cheap is expensive"
Don't hook it up backwards and get an ohm meter and check the terminals. The one that is dead short to the chassis is your neg.
All is true. I had a 77 Honda CVCC years ago. The battery died and I had a friend jump it. I dutifully noted positive/negative terminals on my end, noted red and black cables on his end and hooked up the jumper cables. He turned on his car and phoomph (yes that's a technical term) smoke on my end. WTF! I checked my connections...OK, but his...oh yes, he had put the battery cables (when replaced) on backwards! Ouch...but not the end of the world, I blew the fusible link (not sure where this is on a 92 911) and once replaced all was well. Warning: Big difference in the electronics between a 92 Porsche and a 77 Honda. Don't do what I did....check the cables very, very carefully!
Good luck
Rob Black 1983 911 SC Coupe |
colonel33 - Last I checked batteries were rectangle. If stuff doesn't reach you might think about turning it 180 degrees, or if you like the backward look, buy an Austin Healy 3000. They have a pos ground. Otherwise, set it up correctly.
1989 911 Cab Guards Red 1988 Honda Street 660cc, corners like a wheel barrow |
the ground(-) cable is easy to follow and confirm it`s secured to the chassis.Spend a few minutes
my life begins at 150MPH |
RETIRED
SMOKE.....buy new electrical stuff.....
Ground is attached to the body....most likely a BLACK cable....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Navin Johnson
the pos and neg are also different diameters...
You kinda have to WORK to put them on wrong.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
it would be exactly like a welder, at least for a few seconds.
poof! gone |
A very bright, expensive welder. Followed by replacement, of Alternator, DME, CCU, Spoiler Control Unit, Alarm. . .
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Go Speedracer, go!
1981 SC ROW Coupe |
