vntgspd's Avatar
Need Cam Timing Specs
Okay, I searched but it's the proverbial needle in a haystack. So, here's my plea for help...
I have a 69 911T. The engine was rebuilt with 2.2 "S" pistons, 2.7 "S" crank and rods, and "E" cams. I don't know what year the cams came from but I have never heard of a different range of specs for the "E" cam.
Does anybody out there know what the ideal cam timing for this engine should be?
Thanks!
Old 06-21-2004, 10:08 PM
I would use the cam timing for an E engine 3-3.3mm overlap. Essentially you have a 2.4 L engine. 84 mm bore , 70.4 mm stoke but probably with more compression than the stock 2.4 l engine.. The 69 had a 80 mm bore and 66 mm stroke. the 2.2 had 84 mm bore and 66 mm stroke. Your S pistons have more valve cutout than an E piston would so you may want to experiment with more overlap and see if it gets you anything in the way of hp or torque. The S spec overlap with S cams was 5mm so i would think thatyou have some room to play with if you want. Have fun.
69 911 2.3Ez
85 928S
Old 06-22-2004, 12:02 PM
vntgspd's Avatar
This info is great and makes perfect sense. I knew I could count on someone from the board.
Thanks for the help!
Old 06-22-2004, 12:12 PM
I would rather be driving
jpnovak's Avatar
I bet that is a screamer of an engine. Those 2.2S pistons were 9.8:1 with the 66mm crank. you are well above 10.5:1 with that 70.4mm crank. I just hope they opened the heads on that 2.0T motor for you to take advantage of it.
Old 06-22-2004, 01:01 PM
vntgspd's Avatar
Yeah, it runs pretty good for a 2.4...
0-60 about six seconds flat and 14.5 in the 1/4 mile (car is only 2150 pounds which definitely helps!).
Thanks again for the help!
Old 06-23-2004, 12:55 PM
Early_S_Man's Avatar
Porsche Crest
Well ... there were different timing specs used over the years for the 'E' engines, unlike the early 'S' cams!
Here are the '72 - '73 2.4E specs ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-23-2004, 01:10 PM
vntgspd's Avatar
I have this book for 1970-71 but I didn't have the data you gave me. I think they are the same but it's good to confirm. Thanks!
Old 06-23-2004, 01:27 PM
the '70-71 book should show 3.0-3.3 for the E
I timed to 3.1.. the differences may have been due to smog.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-23-2004, 03:20 PM
