CIS Cold Start easy fix
I was beginning to have cold start problems with my 82SC and was sure I would be spending a considerable sum for a new WUR and Cold Start Valve. Before buying the pressure gages from Witney, to do the necessary pressure testing, I decided to add some fuel injector cleaner to my fuel tank which was about 3/4 full. Volia!! it did the trick. No more cold start problem. I suspect that the cold start valve was dirty and the injection cleaner took care of the problem.
Guy Chiattello 82SC Black Coupe |
Designer King
Congratulations on your easy fix.
If only they were all that easy. You may want to do a search. Many have recommended 2 tanks w/ Techron, followed by an oil change. Paul
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I want your luck!
