Alternator / starter / EFI wiring help
converting my 79sc 3.0 to EFI and looking for some verification with wiring.
I just received my new Alternator which is INTERNALLY regulated.
Stock Alternator has
1. Large red / small red wire
2. black wire
3. blue wire
4. 3 brown wires
5. 1 brown wire to engine case
Since this is internally regulated, I am assuming I just leave the Black , Blue, and one brown wire out of harness.
There is only two studs on new Alternator.
I am assuming 3- gets brown wire to engine case and 3+ gets red wires
The starter has three wires
1. Thick yellow
2. thin yellow
3. large red
I believe the thin yellow with blue strip goes to cold start injector?
Thick yellow is to fuel pump relay
can someone please confirm
Old 02-09-2016, 03:29 PM
ROW '78 911 Targa
timmy2's Avatar
Only the black wire DF is not used.
Thin yellow can be deleted.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-09-2016, 05:19 PM
DF? Sorry English please. I am not good with electronic stuff.
I followed the wires from alternator and the black, blue, and brown wire all run into the voltage regulator.
Old 02-09-2016, 05:29 PM
ROW '78 911 Targa
timmy2's Avatar
DF is the designation on the prints for the feed to the voltage regulator.
Dennis
Old 02-09-2016, 06:22 PM
ROW '78 911 Targa
timmy2's Avatar
You can delete a lot of wiring in the '79 engine harness depending on what EFI system you are installing. Give more details and I can give you guidance as I've built a lot of custom engine harnesses for people.
Dennis
Old 02-09-2016, 06:26 PM
ROW '78 911 Targa
timmy2's Avatar
I see 3 studs on your alternator. One for reds, one for Blue and one for ground.
PM me your phone number and a time to call and I can talk you through the alternator and the wiring for your engine harness.
(I'm on the west coast for time considerations)
Dennis
Old 02-09-2016, 10:57 PM
