twin plugged targa's Avatar
please identify these twin plug components
Hi Guys
I will be heading back to France to try resolve my ignition problems (detonation) and suspect a slipping dist. belt.
I have ordered the vent kit and new belt and figure I should probably get new caps, rotors and maybe coils?
Here are 2 pics of my twin dizzy setup from a 964 I believe.
I believe the dizzy is customized to trigger the spark? - Have read a bit about this but memory is fading.
However I believe the correct caps and coils would be for a stock 964 ignition setup?.
Please let me know what you think and if these are 964 dist. caps and coils?
Many thanks
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 06-25-2004, 05:08 PM
yes, yes, and yes- to all your questions/ except the black coil looks like a SC unit (pic makes it look shorter than the alu. 3.6 unit)- great looking car and c'est si bon d'avoir une targa pour courir avec- bon voyage!
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 06-25-2004, 05:14 PM
POVI's Avatar
Hi ,
Yes you have a 964 distributor setup , with some custom dual cd boxes
and electronics id guess.
What you should check first if the slave distributor rotor ( the one that is driven from the main dtributor via a belt ) will turn freely by hand
if so then you have a broken belt ..that would cause your miss fires
and detonation ..i had the same thing happen to my 3.6
If you have a new belt ..its a pain but not too hard to disassemble and replace belt.
take care
Joe
that happened to me also
Old 06-25-2004, 05:16 PM
Thanks guys
I will order the rest of the parts of PP right now,
The symptoms are that the car detonates at higher revs when under load (over 4k revs) but I checked both banks of plugs for sparks at idle and they seemed healthly.
I am assuming the belt is slipping at higher revs if this is possible?
I will change out the other ignition components for good measure.
PS there are no apparent mechanics near its location, which is South Normandy, France.
Thanks again
Ben
Old 06-25-2004, 05:25 PM
Check total advance- you can run 31-32 degrees on the best gas there. If your compression is much over 10.3:1, then consider backing off the timing to 29 degrees and see how the car behaves.
Better yet- check pelican for the innovative motorsports kit. the on board diagnostic capability it gives you will enable a mechanic to dial in the carbs and timing correctly
1970 911 Targa "ST"
Old 06-25-2004, 05:33 PM
Thanks TRE Cup - wil check it out,
rgd Ben
Old 06-25-2004, 06:15 PM
