please identify these twin plug components
Hi Guys
I will be heading back to France to try resolve my ignition problems (detonation) and suspect a slipping dist. belt. I have ordered the vent kit and new belt and figure I should probably get new caps, rotors and maybe coils? Here are 2 pics of my twin dizzy setup from a 964 I believe. I believe the dizzy is customized to trigger the spark? - Have read a bit about this but memory is fading. However I believe the correct caps and coils would be for a stock 964 ignition setup?. Please let me know what you think and if these are 964 dist. caps and coils? Many thanks Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
yes, yes, and yes- to all your questions/ except the black coil looks like a SC unit (pic makes it look shorter than the alu. 3.6 unit)- great looking car and c'est si bon d'avoir une targa pour courir avec- bon voyage!
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Hi ,
Yes you have a 964 distributor setup , with some custom dual cd boxes and electronics id guess. What you should check first if the slave distributor rotor ( the one that is driven from the main dtributor via a belt ) will turn freely by hand if so then you have a broken belt ..that would cause your miss fires and detonation ..i had the same thing happen to my 3.6 If you have a new belt ..its a pain but not too hard to disassemble and replace belt. take care Joe that happened to me also |
Thanks guys
I will order the rest of the parts of PP right now, The symptoms are that the car detonates at higher revs when under load (over 4k revs) but I checked both banks of plugs for sparks at idle and they seemed healthly. I am assuming the belt is slipping at higher revs if this is possible? I will change out the other ignition components for good measure. PS there are no apparent mechanics near its location, which is South Normandy, France. Thanks again Ben
Check total advance- you can run 31-32 degrees on the best gas there. If your compression is much over 10.3:1, then consider backing off the timing to 29 degrees and see how the car behaves.
Better yet- check pelican for the innovative motorsports kit. the on board diagnostic capability it gives you will enable a mechanic to dial in the carbs and timing correctly
Thanks TRE Cup - wil check it out,
rgd Ben
