Raynald's Avatar
What is wrong with my weber ?
Hello All !
i have a small problem with my adjustment of weber ...
at 3200 rpm ,i have pop in my carb. my engine is running great at idle and 3500 rpm and more...it is a 2.7 liter with 60 idles jets and
135 main jets, ventury 34mm, i think my timing is good,
do you think my weber is too lean at the beging of main stage...?
or i mist some other adjustments,
Raynald
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 06-26-2004, 03:30 PM
Sounds like partially plugged idle jet; unscrew 'em, blow 'em out, reinstall. Takes 10 minutes. Happens to mine all the time.
David G PCA
'72 S/T
'74 Euro Carrera
'95 RS --SOLD
'77 930 Steel Slantnose "Wedgie"
'57 Speedster planter
Breeding family of Volvo/ BMW Wife + kid mobiles
'Rib-Breaker' '01 CRG 125 shifter kart
Aprilia RS50-weedeater with fairing
Old 06-26-2004, 05:58 PM
Nitrometano's Avatar
May be is a little lean. My webers do the same when they are out of calibration.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-26-2004, 06:13 PM
I'd agree with David,....its likely a clogged idle jet or two.
David,...........................I must tell you that this doesn't need to be a regular occurrance,... With proper air and fuel filtering, its a VERY rare event.
Here are few suggestion for keeping Weber's (and any other carburetor) trouble free:
1) Make sure the tank is absolutely rust free and the in-tank filters are clear
2) Use a fuel filter that removes debris down to 1 micron. I use a Racor 110A.
3) Throughly clean the air cleaner housing(s) and use a layer of grease on the rubber ends of the air filter element(s). This keeps dust out.
4) Replace or eliminate the sound proofing pad between the cabin & the engine compartment. When they are old, they sluff off tiny particles that always find their way into the flow bowls, and thus into the idle passages.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-26-2004, 06:31 PM
joehahn's Avatar
nice tip steve on sound pad. when i gave up fussing and handed car over to mechainic he took one look at my crumbling engine sound pad and said "that's the culprit". crap falling off everywhere. removal plus rebuild and i am tight for 1.5 years.
Old 06-26-2004, 06:46 PM
Raynald's Avatar
is this possible my carb are not good balance over 3000 rpm ?
Raynald
Old 06-26-2004, 07:05 PM
A Quiet Boom's Avatar
Originally posted by Raynald
Raynald
Not sure I know what you mean by that. I'm in agreement with the others, check you idle jets. I assume the car runs smoother when you're deeper into the gas pedal. There's been a lot of threads about this lately with both webers and zeniths. Mine had a clogged jet on one cylinder so it was terrible at part throttle but fine at full throttle when you're pulling primaily from the main circuit. I like the adjustment instructions in the Hayne's manual best for sychronizing and adjusting the carbs.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 06-26-2004, 07:38 PM
Originally posted by Steve@Rennsport
2) Use a fuel filter that removes debris down to .1 micron. I use a Racor 110A.
hmmm.. I bought five 2 micron spin on filters for the 120 model. I guess I'll be ok. I didn't know 1 micron was available? meanwhile I have it in my head that the routine is 10 microns...
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-26-2004, 08:04 PM
I'd say 10 microns would be sufficent since that's about 0.0004 inches or 0.01 mm. My idle jets for example are 0.62mm or 620 microns! I'd think a 0.1 micron filter is a little extreme. Having said that however my tank probably has a little rust, the internal filter has never been changed and I use a generic filter. Still I think my clogged idle jet was caused by varnished gas due to winter storage or debris left from rebuilding the carbs. Heck it could have even been something in the fuel line after the filter for all I know.
Old 06-26-2004, 11:41 PM
Raynald's Avatar
Hello All
today i do your recommendations, i removed all idles jets and check all no problem there... i do a mixture ajustment and all have reaction of turn and all is Ok at 3 turns and haft out, my idle is stable...
my problem is at 3200 rpm i have a pop on high-way in carb...
at this RPM it running on the main circuit ?
Raynald
Old 06-27-2004, 07:46 AM
Raynald's Avatar
hello
i check my plugs all is the same color cofee-moka...
what is the next step...?
Old 06-27-2004, 08:21 AM
The pop on the highway, how far down is the gas pedal? Also how did you check the jets? I usually check them with the appropriate sized pin drill but a thin piece of wire also works. My guess is you're still mostly using the idle circuit on the highway, how does it do at full throttle, any pops then?
Old 06-27-2004, 09:11 AM
Raynald's Avatar
Christian
it is hapening only in highway at around 100 KM./H. when i try to accelarate i hear a pop in weber, my pedal is in meedle and after the pop i have a good accelaration, in city i don't saw the problem,
i saw the springs around the mixtures screws is not very tight my screws is moving by side after 3 turns and a hafts out !!! is this normal ?
can this afect my adjusment ?
Old 06-27-2004, 11:16 AM
maybe check the accelerator pump flow.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-27-2004, 11:18 AM
Yep, check those accelerator pumps. It should squirt fuel even with small movements of the butterflies. Those screws do seem a little loose, but without seeing them I can't say for sure. I'd be tempted to try a 61-63 idle jet and turn those screws in a little. Take one of the screws out and check the o-ring on it, if they are missing or broken you'll pull air past them and cause the car to run lean and the screws to be loose. Have you adjusted the accelerator pump linkage?
Old 06-27-2004, 11:59 AM
Raynald's Avatar
Thanks,
i rebult my weber 2 years ago and i have adjust my pump ,if i remenber i have 6 cc of gas on each bank,
but i think my mixture screws is too out , it will be a good idea to orders bigger idles jets and turn more in my screws i can move it side by side.
and i will check for the carb balance at 3200 rpm,
Raynald
Old 06-27-2004, 12:33 PM
Raynald's Avatar
Good news !!
i make progress ! i have check the carb balance at 3000 rpm and everything is fine ! i have old mains jets of 105 and i drill it a little more of my new 135 (estimation of 145 or 150) and i try it to night and no popping at 3200 rpm...
i will try it tomorrow with a long run !
i hope i will have resolve my problem...
Raynald
Old 06-30-2004, 06:30 PM
Gasoline User
1974carrera's Avatar
Raynald, please do report your findings after you drive it. Based on the description that the engine pulls well at higher revs and greater throttle openings, I wouldn't necessarily think that the main jets need to be larger. Your description sounds like the pop occurs when the throttles are transitioning more into the main jets which does seem like an accelerator pump issue. Might be worth it to check their discharge again just to be sure...? Did this popping issue just occur or has it been doing it all along?
By the way, I was looking at the pics of your car on your link and it looks incredible. You did a really nice job restoring it! Are the black paddle Fuchs in some of the pics 7" & 8" X 16's? and what's up with that exhaust...what is it?
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 06-30-2004, 07:14 PM
Raynald's Avatar
Hello Bob,
i will recheck my accelerator pump again to be sure ! but my english is not perfect i can not explain perfectly my problem,when i stay at 3200 rpm on hightway it is poping some time, not when i do acceleration
it is like my weber are too lean at the begin of the main stage...
my fuchs are 7 and 8 X 15 inchs i restaured ... a lot of sand-paper... and time and the muffler is Dansk i brought it from jasper a pelican member
Old 06-30-2004, 07:41 PM
Hello Bob,
That sound a lot like the idle jets to me, try one or two sizes bigger and see what happens. I really don't know why they call them idle jets, they should correctly be called part throttle jets.
Old 06-30-2004, 08:53 PM
