Rotor buttons for SC distributors - how do you raise rev limits?
Hi all
My 2.7 presently has a single plug dist'r with a 7300 rpm rev limit rotor button.
I am replacing the dist'r with a 964 based twin plug set up with SC internals. The standard SC rotor button has a 7000 rpm rev limit right?
QN: Can you get SC rotor buttons with higher 7000 rpm rev limits? or do you have to move to a stand alone rev limiter?
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 06-27-2004, 11:50 PM
I thought all SC were rev limited by the CD box rather then the rotor??
Ben
Old 06-28-2004, 05:48 AM
SC-targa's Avatar
I believe that ROW cars were controlled by the rotor.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 06-28-2004, 07:22 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
ROW cars used a rev limiting rotor, NOT the same as the 2.7 rotor. The Row rev limiting rotor for SCs has a 6800 limit, and that is the only one I am aware of. It is also bigger and spins the opposite direction than the 2.7 rotor. Pelican unfortunately does not sell them (unless they have recently added them). I got mine from Vertex for ~$22. If you want to go higher than 6800, I think you will have to go with a stand alone limiter.
1981 SC ROW Coupe
Old 06-28-2004, 07:28 AM
