Install this how?
Help! What's the trick to installing a replacement engine compartment soundproofing mat? Original mat deteriorated on my 88 Carrera, messy.
Old 06-28-2004, 05:15 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I think the trick is removing the engine.
1981 SC ROW Coupe
Old 06-28-2004, 05:27 AM
Semper drive!
rcecale's Avatar
That certainly would make it a lot easier!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-28-2004, 05:29 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
You can also just loosen the rear engine bolts and the engine drops down several inches. Gives you a little more room, but obviously much easier to remove the engine. I did mine just lowering the engine and worked out OK.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-28-2004, 05:35 AM
I swapped mine without dropping/loosening engine. Not a big deal. That forgiving 3M spray adhesive makes the job a bit easier - you can modify the installation if necessary as you go.
Old 06-28-2004, 07:49 AM
