Can't get the CV boot over the cap/flange. Photo
Tried and tried and do not want to tear it...can't get it over the cap.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
This is as far as I can get it. What am I missing here?
The best way I have found to do this is to get the boot on the flange before you put it on the driveshaft. My procedure is as follows:
1. Install boot on flange. 2. Slide small end of boot over driveshaft. 3. re-install CV joint onto shaft. 4. push flange back on CV joint. 5. insert retaining clips onto boot ends and driveshaft end. 6. Install on car. I hope this helps!! Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
are you installing or removing? if youre installing wrap the splines in
electrical tape and grease it up. worked for me. if youre removing, whats the point? buy new ones and rip the old ones off. oh yeah and what ever the case remove that cv joint off the boot before doing anything
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
oops our boots are not alike. scratch that, i see the problem.
hmm, try really small pliers with the ends wrapped too get that last little bit around.
i clamp the cv in a vise, (across the diameter), tap the metal flange on, then use a dull hooked tool to work the boot in place. it is a PIA, but you get better at it after doing a couple. then tap the flange off the cv after installing the clamp, and put the boot/flange onto the axle shaft first, followed by the cv.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-27-2004 at 05:02 PM.. |
Kantry Member
I just did this the other week-end. As James said, fit the boot to the flange first. I used a little silicon spray to lube the inside of the boot, then gently stretched it on over the flange. Then work the boot onto the axle shaft and install the CV joint. Should only take a minute or so.
Les
Best Les My train of thought has been replaced by a bumper car. |
The only success I've had is as the others have said - before the boot/flange assembly is on the axle. It's impossible once they're on the axle and full of grease. Infuriating, to say the least. Had two pop off yesterday during an engine drop.
Greg |
Won't the boots with the built-in flanges fit your CV's?
IF not, or if you are determined then use the dull hook or padded pliers methods above. Good luck. |
They are on! I don't exactly know how, but I followed the consensus, and put them on with the flange/cv off the axle. Like they had to be "worked over" the top, the last edges a REAL PAIN..to the hands, and I used gloves
Fantastic!!!
James
Greg |
