| Registered Join Date: Jun 2004 Location: SC
				Install this how?
			Help! What's the trick to installing a replacement engine compartment soundproofing mat? Original mat deteriorated on my 88 Carrera, messy.
|  06-28-2004, 04:15 AM |
| Go Speedracer, go! Join Date: Aug 2002 Location: Indianapolis
			I think the trick is removing the engine.
				__________________ 1981 SC ROW Coupe | ||
|  06-28-2004, 04:27 AM |
| Semper drive! |
			That certainly would make it a lot easier! Randy
				__________________ 84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten  ) One Marine's View Igitur qui desiderat pacem, praeparet bellum | ||
|  06-28-2004, 04:29 AM |
| Registered |
			You can also just loosen the rear engine bolts and the engine drops down several inches.  Gives you a little more room, but obviously much easier to remove the engine.  I did mine just lowering the engine and worked out OK.
				__________________ Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD | ||
|  06-28-2004, 04:35 AM |
| Registered Join Date: May 2003 Location: Vancouver or... ?
			I swapped mine without dropping/loosening engine.  Not a big deal.  That forgiving 3M spray adhesive makes the job a bit easier - you can modify the installation if necessary as you go.
|  06-28-2004, 06:49 AM |
