skipdup's Avatar
PPI Compression and LeakDown Results - '79 930
I had a PPI done on a 1979 930 I'm considering buying which shows 21K miles.
Compression came back at 135 for all six cylinders and 110/110 for all six.
I thought results like this were impossible. When I asked the mechanic, he said it was uncommon, but that he does see it occasionally.
Any thoughts?
Thanks!!!
Old 06-28-2004, 01:13 PM
skipdup's Avatar
also... I searched for what the numbers should be and came back with nada...
Friend of Warren
Well 135 in all 6 cylinders for compression is good, but I don't understand the 110/110 for a leakdown figure. Normally it is expressed in percentages. Anything less than 5% leakdown is good. Is he trying to say the leakdown is 0%? If so, then I question the accuracy of the test. Every cylinder will have some leakdown as no cylinder is air tight!
Kurt V
Old 06-28-2004, 01:16 PM
skipdup's Avatar
The "110 over 110" is what I was told over the phone. I THINK he was telling me 0%. I'll find out for sure this afternoon when I go back to pick up the report.
Thanks.
Old 06-28-2004, 01:24 PM
Not Quite Banned
Thomas Owen's Avatar
Even an engine that had vitually no miles will show some leak. I agree with Kurt that it should be between 1 and 5%. Don't be afraid to ask for a re-test!!!
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 06-28-2004, 02:23 PM
ewave's Avatar
Hey skip- If you are looking in Dallas, check out this one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2482753269&category=6433
Also I've done my own leak down tests, and with 100 PSI on a 3.2L engine I got close to 0% leakdown, (less than 1 psi drop). I was surprised. This was with an engine that clamed to have only 15K miles on it.
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 06-28-2004, 02:44 PM
skipdup's Avatar
Yup, looked at that car a month ago... Looks like they are having a tough time selling. Thanks for the head-up though...
Old 06-28-2004, 04:45 PM
When I bought my 930 motor, I did a leakdown. I got 1% to 2.5%. Most were 1.5%
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-28-2004, 07:10 PM
I had the engine rebuilt on my 89 930 when I got it (broken rings). I did a break-in drive of about 1000 miles up and down hills, full throttle then engine braking, etc. When I took it in for the 1500 mile service, I had the mechanic do a leakdown. He said he got 0% leakdown on all 6 cylinders (the needle just moved off the peg on the gages but didn't show on the scale). I didn't believe it at first but I've heard similar stories since then.
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 06-29-2004, 10:50 AM
skipdup's Avatar
Well, the report shows all cylinders at 135 compression. None leaked, except cylinder #2, which dropped from 110# to 100#.
Thanks to all for the input.
- Skip
Old 06-29-2004, 11:29 AM
Wow. How much is the car, if you don't mind my asking?
Beethoven
'88 911 Coupe
Old 06-29-2004, 11:46 AM
skipdup's Avatar
Beethoven- All the dirty details here
Old 06-29-2004, 01:33 PM
