TSwede's Avatar
Also - another thing...
When I take my foot off the throttle - not driving - just revving the car up - it deccelerates nice and quick but then hangs around 2000 RPM ish for a second or two before continuing back to tickover - the car has always done this - annoying...
Can anyone tell me how to solve this????
Cheers All
TSwede
Old 06-29-2004, 07:42 AM
Designer King
Paulporsche's Avatar
Try plugging the line to the top of the decel valve.
Also, check to see if you are not running too rich.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-29-2004, 07:56 AM
TSwede's Avatar
Hi - What's the Decel valve??
Excuse my ignorance...
TSwede
Old 06-29-2004, 08:39 AM
Designer King
The deceleration valve is a small yellowish metal unit located to the left of the rubber air flow bellows on the top of the air box (when viewed from the back of the car). It kind of looks like a pear or a small pineapple. Its job is to slow down the decelleration of the engine the way you have described it, originally as a way to reduce emissions. There is a vacuum line connected to its top. You can try disconnecting and plugging that line, as well as the tube on the top of the valve. Or you can try adjusting the valve by turning the nut on the top of the valve that surrounds the tube. I have never done this, but I hear it can be done. When I got my new engine, my mechanic actually left the vacuum hose disconnected and the car ran fine.
If you search, you should find some photos. Or get the 911SC manual from Bentley. Even though it is for SCs, a lot of the info pertains to S models.
Paul
Paul
Old 06-29-2004, 09:43 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
what Paul said...I just disconnected it and plugged the hose.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-29-2004, 11:00 AM
TSwede's Avatar
Wahayyyyy!!
It worked... blocked off the valve and bingo!!!
Timing is OK ish now but the mnarks jump around alot - the person who built up my engine a couple of years ago said it's pretty worn - a job for the future..
Just one more thing to ask - upon deccelerating when driving I get a bit of 'popping' - sounds racey but is it healthy or a sign of evil?????
TSwede
Old 06-29-2004, 11:53 AM
}{arlequin's Avatar
evil, but the healthy kind...
dave
1973,5
Old 06-29-2004, 12:17 PM
Montana 911
k9handler's Avatar
oh yeah...you should here it when my 3.6 with no mufflers does it, then again it's only under a real hard decel that it will pop a bit.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-29-2004, 08:39 PM
