What rear caliper has 48MM piston
Does anybody know what 2 piston ATE cailper for the rear of a 911 has a 48MM piston. Thanks in advance.
Old 06-29-2004, 01:07 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
I think it could be the M caliper. first used in the rear on Carreras. pretty sure it uses the same size PAD as the earlier Ate rear caliper. If nobody else chimes in I will double check my M's when I get home.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 06-29-2004, 01:18 PM
jpahemi's Avatar
Hello,
From ATE for rear 911 application: none. The largest 2 piston cast iron (steel) caliper has 42 mmm (3.2 911).
Regards,
J.P.
Ps. The fronts have 48 mm (3.2 911).
Old 06-29-2004, 01:20 PM
911ctS's Avatar
yep he's correct. the M caliper is 42mm, A caliper 48mm, and S caliper is 48mm.
note: the M caliper has 3" bolt spacing, the A and S have 3.5"
Clint Smith
Old 06-29-2004, 01:25 PM
KobaltBlau's Avatar
What are you trying to do, Jeremy?
Andy
Old 06-29-2004, 01:35 PM
A friend needs to purchase a caliper kit for these unknown rear calipers.
So these could be A front calipers mounted on the rear?
Old 06-29-2004, 01:42 PM
KobaltBlau's Avatar
In all likelihood, yes, especially if the calipers have 3.5" hole spacing (mounting would have to be modified). What does he have on the front? Hopefully something bigger than an 'A'.
Andy
Old 06-29-2004, 01:59 PM
Bill Verburg's Avatar
You will find data on 911 brakes here
There are 48mm piston Ate calipers w/ 3" ears but they were never oem on any Porsche
There are several versions of the M caliper differing in piston size, mount dimension and throat size
There are versions of the M caliper w/ 3.5" mounts which can be bolted to 930 trailing arms.
A calipers are noticably larger than Ms , there are pics on the link I posted.
Bill Verburg
Old 06-30-2004, 05:39 AM
KobaltBlau's Avatar
The brake oracle has spoken!
Andy
Old 06-30-2004, 06:27 AM
Thanks Bill, great link! Thanks to the rest for your input as well.
Old 06-30-2004, 06:46 AM
I stumbled across this thread since I am in the same situation described above. The car I have (69E) came with Ate 51R rear calipers with have the 3" ear spacing with 48mm pistons. I need to get a seal kit for at least one of them. Can anyone help me with identifying what car these came from so I can find the parts?
Darren
Old 11-19-2013, 09:32 AM
Darren
They are M fronts from any year, you really should replace them w/ the correct rar 38mm M rears
Bill Verburg
Old 11-19-2013, 10:00 AM
