Exhaust Diameter Question
The outlet of my SSIs seem to measure about right at 2" in diameter. Hypothetically, would bolting a 2.25" exhaust to the SSIs be a bad idea? Is this one of those situations where "close" counts?
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
It's not so much the size differential as the sudden transition. Much better to have a smooth transition.
That said w/ a muffled system it doesn't really matter all that much.
Beyond what BV siad, you could call up John Daniels. He created the system and has done dyno testing on various pipe dias. I expect he will tell you to avoid the larger pipe.
Hmmm..decisions.... Of course, the larger muffler inlet diameter will cause the exhaust gases to slow slightly, but I bet the answer to this question is not really simple. I might be able to smooth the transition somewhat...
Randy - for sure the larger pipe diameter would be detrimental, but hopefully the SSIs will take care of the vast majority of the exhaust system flow. Truth is, I found a decent deal on some stuff on ebay, but the exhaust is 2.25" in lieu of 2".... Mike
The muffler will sig'ly affect the restrictions in the system and hence total pressure. It will also damp pulsations ("scavenging"). So it's not that big a deal. Buy it. Or call SSI and then buy it.
Definitely smooth the transition... If you search for that marathon exhaust thread you can find the title of a book I posted on this topic. If you want to get into it that far... |
There is nothing wrong with going to a slightly larger pipe transtion, its only a problem when you go the other way.
Just imagine what transition the gas sees when it leaves the exit of the exhaust pipe. |
Ah, but the end of the pipe is not the middle or end.
There can indeed be problems - they have been demonstrated empirically and shown theoretically and with numerical methods. Remember you are disrupting the flow. Do this: whenever you think about flow in a tube, think about flow in a river or canal. That will get you part way to understanding potential problems. Here, there will surely be turbulent eddies induced - and that will mean higher resistance. |
Crotchety Old Bastard
Slide your 2.25" ID exhaust over a 2" ID pipe that is welded to a flange that will bolt onto the SSIs. Good enough for a street motor.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thanks for all the replies. Mike
