Wrinkle paint
Any hints as to preferred application of black wrinkle paint? Is heat suggested? Suggested brands?
Thanks, Sherwood |
Sherwood,
I used some I bought from Summit Racing for my valve covers. It was a very faint wrinkle finish and came out well. If you put too much paint on you will lose the wrinkle effect. Pretty happy with results, but I would powdercoat if you can. John
1985.5 944 GTS |
I used it on some Chevy VC's around the Corvette script ala Ferrari. Took me half a day to mask and 10 min to paint. Always the way, eh? |
Forced Induction Junkie
I used PJ1 Coatings Special High Temp(500deg. F) Wrinkle Finish Paint. Put two medium coats on the valve covers and then baked at 200deg F in the oven to develop a good wrinkle texture.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I just powder coated a valve cover for my Toyota today in wrinkle red. Very Ferrari like
It was the first time I coated anything with a textured finish and I'm very happy with how it turned out. I'd assume the prep work is the same for paint. I cleaned it very well with brake cleaner and a green scrubbie. Then with alcohol and a lint free cloth. I then heated it up to bake off any grease and outgas the aluminum. After that it was normal powdercoating process.It doesn't photograph well though....
I baked mine and my wife was not happy with it. It turned out well though. Eastwood wrinkle paint, black.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Those all look great -- but aren't they hard to keep clean?
Actually, the wrinkle paint is easier to maintain than polished aluminum or a flat painted surface. I just use a soft cloth to clean them once and a while to get the dust of the valve covers. The wrinkle finish seems to scatter light so irregularities are harder to spot.
30 yrs ago I used that stuff on motorcycles. Turned out great, but it is hard to keep clean
