dickster's Avatar
finally found time to install turbo tie rods and ERP drop links
started by jacking front of car and removing both wheels.
heres the old ones
heres why i need drop links - out end of rod much higher than rack end.
remove rod ends first - left side fell out with hammer applied
other side wasn't so easy.
hammer and special removal tool wouldn't work so got the drill out!
i ground down the threads and then drilled the centre out with 8mm drill - fell out with a tap of the hammer.
more to follow after the football.......
Rich
'86 coupe
"there you are"
Old 07-04-2004, 10:42 AM
dickster's Avatar
remove tin protecting rack and fuel pump
remove springs retaing rubber boots so that boots can be pulled to one side.
remove rods. left side just need turning to 90 degrees, right required blunt chisel to retaining nut.
rods removed from car.
old v new rods
Rich
'86 coupe
"there you are"
Old 07-04-2004, 12:48 PM
dickster's Avatar
assemble new rods same length as old. i replaced turbo rod ends with spherical bearing type supplied with drop link kit.
assembled apply thread lock
screw on new rods to rack (replace rubber boots before this if using turbo rod ends, and i also did not need the large washers/spacers supplied)
Rich
'86 coupe
"there you are"
Old 07-04-2004, 12:52 PM
dickster's Avatar
refit rubber boots - i lubed the ends with engine oil to ease fitting.
i also used zip ties - i gave up with the spring retainers!
Rich
'86 coupe
"there you are"
Old 07-04-2004, 12:55 PM
dickster's Avatar
assembled droplinks.
finished left and right sides
refit rack protection/wheels etc. it can be a PITA to get the rear bolts in the rack cover tin (sway bar support) and i found it much easier if i tightened up the front nuts first - this pulled the rear into line.
only a small gap now
Rich
'86 coupe
"there you are"
Old 07-04-2004, 12:59 PM
dickster's Avatar
drives great.
now i need an alignment.
Rich
'86 coupe
"there you are"
Old 07-04-2004, 01:01 PM
Binge User
Schrup's Avatar
Rich, car looks great!!! How low is it now? Do you plan to go lower? I am posting this link for anyone (like myself) that wonders why you would leave off the spacers.
Turbo Tie Rods - Install Spacing Washers or not?
Paul
Old 07-04-2004, 01:25 PM
Steve W's Avatar
Rich, not sure how you got by without using the rack spacers, as they're not really spacers but rack stops. Some guys on this board also did without the spacers and ruined the steering rack in no time.
Steering Rack Failure
Old 07-04-2004, 01:55 PM
Zeke's Avatar
I too, thought there was an necessity for the spacers. I know they look like the shorten the amount of usable thread, but I put them on just the same.
I see a Stanley dual scale tape measure. Do the Brits look at the inch scale much?
Old 07-04-2004, 03:03 PM
Silveresrty911S's Avatar
Rich, it also looks like the front torsion bar adjuster is backed WAY OFF! Unless you just did that, I've been under mine all weekend installing new 22/28 t-bars so everything looked familiar except the 11mm bolt for adjusting the height.
Thanks for the write up as I'm doing the turbo's next week.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 07-04-2004, 06:07 PM
Binge User
Schrup's Avatar
Rick, what kind of shocks do you have & are they new?
Paul
Old 07-04-2004, 06:15 PM
Send a message via Yahoo to Lukesportsman
Thanks for the write up for those of us getting ready for this improvement. Got to love you Brit's garages. I lust after them in the back of CSC Magazine every month. Just love the carriage house look and quality wood construction over our "manufactored" looking garages.
Did you light a firecracker for us tonight
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 07-04-2004, 06:37 PM
dickster's Avatar
thanks! its at about 23.75/24.25 r/f - no i would prefer it slightly higher - 24/24.5 - thats what i'll aim for with an alignment when everything is done. the A arms are pointing the wrong at the moment.
the spacers are left out with the ERP drop links, the instructions say so! and i confirmed with smart racing (as i said in the thread you refer to).
steve, yeah i know, and without the ERP kit i would have used them.
the ERP kit has been improved with longer rod ends which necesitates (sp?) discarding the spacers.
funny! actually i still prefer inches - can't get my head round the metric system.
i adjusted the height when i did the t/bars. i hope you find it helpful - it was pretty easy, the only PITA was a rod end i had trouble with, but now i wouldn't waste time, i would just drill it out.
i have the bilstein sports, and they're pretty new. they need revalving for the t/bars though.
thanks. its my parents place - but i got my eye on it.......
but i have to confess (on the old mans behalf) that it is block construction with timber cladding (planning requirement as its in farm land area) - still it looks nice!
sorry, i got side tracked by the football - but i did think of it - happy (belated) 4th july
Rich
'86 coupe
"there you are"
Old 07-04-2004, 10:35 PM
dickster's Avatar
the car feels much nicer, the steering more direct. the drop links have made the car alot less "darty". i think i may have found a cure for the strange - one sided - understeer problem i was chasing. it may have been the old rubber jointed steering arms, because first impressions are that left right turns are now the same.
definitely recommend the turbo kit for anyone, and the drop link for all your lowered cars.
Rich
'86 coupe
"there you are"
Old 07-04-2004, 10:39 PM
AirCooledExcellence's Avatar
Good job Rich!
There's definitely 'night & day' difference between the old rubber ones & turbo rods, those drop links look cool too!
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 07-05-2004, 07:20 AM
Glasgow 911SC's Avatar
Are these the 9meister drop links Rich?
How's the wee man by the way? He's keeping you busy I guess.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 07-05-2004, 10:30 AM
Driving member
jester911's Avatar
Looking good Rich. Thanks for the replies on my post on generally the stuff I am talking about on my car.
Bet it feels great
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 07-05-2004, 10:49 AM
dickster's Avatar
hey jerry, yeah it feels great to get it done at last! i've had this stuff lying around for ages.
good luck with yours.
chris,
no, these are the smart racing ones.
he's doin great - teething - thanks for asking (and remembering ).
tim,
yeah, they do feel good - hopefully i've cured the handling probs now.
Rich
'86 coupe
"there you are"
Old 07-05-2004, 11:54 AM
