ckmaggie's Avatar
I need alarm help!
I needed to disconnect my battery. Upon connecting it back, my factory alarm (for which I have NO key) is going off. Short of pulling the horn, what can i do?
Chris
Chris
1985 Carrera
http://www.pelicanparts.com/gallery/ckmaggie
Old 07-03-2004, 10:49 AM
D idn't E arn I t
RANDY P's Avatar
leave the key in the on position when you plug the battery in. Try that.
rjp
In the movies only bad guys sleep in king size beds.
Old 07-03-2004, 10:50 AM
wastintime's Avatar
Send a message via AIM to wastintime
NO!!!!!!!!! do not leave the key in the on position when you plug it back in. you can fry your DME!!!!!!
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 07-03-2004, 10:52 AM
D idn't E arn I t
RANDY P's Avatar
So what happens when the battery dies and you have to jump start the thing? That, is infinitely worse, but happens every day somewhere.
Only other thing I can think of is tugging the fuse that ties into it. You sure it's not an aftermarket? The horn is going nuts and not a siren somewhere? From what I understand the master key should disable it..
Good luck
rjp
Old 07-03-2004, 11:12 AM
ckmaggie's Avatar
I should have been more clear. The alarm is factory (my owner's manual references it as an option) and the horn for the alarm is attached to the front subframe next to the steering rack. I could get under there and disconnect wires but I would rather not. Several items need to be removed to get there.
Chris
Chris
1985 Carrera
Old 07-03-2004, 11:17 AM
david914's Avatar
Remove the cover in the trunk over the fresh air blower. The alarm brain (larger black box) is under/behind the fresh air blower box next to the intermittent wiper relay (the smaller black box). Remove the connectors from the box and you should be OK.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 07-03-2004, 11:24 AM
D idn't E arn I t
RANDY P's Avatar
According to my owners manual, (Mine's an 81 - I know you're an 85 but it's all I have in front of me) is that it can only be activated by a special key - guess it's not the one for the ignition. In other words, unless you specifically turned it on before you started this whole thing it's probably not it.
Not to second guess but are you sure it's not an aftermarket? an LED on the dash, or any odd toggle switches anywhere, or extra fuses around the battery?
If you see any odd hidden butons or switches that aren't factory, turn the car to on and hit the button...
lemme know -
Old 07-03-2004, 11:25 AM
ckmaggie's Avatar
It is fixed. I am really a dumb a#% some times. I just hooked the battery back up, ran and started it up and once she turned over it shut off in about 2 seconds.
Thanks for the quick suggestions
Chris
Chris
1985 Carrera
Old 07-03-2004, 11:54 AM
