Wrinkle paint
Any hints as to preferred application of black wrinkle paint? Is heat suggested? Suggested brands?
Thanks,
Sherwood
Old 07-05-2004, 04:38 PM
North Coast Cab's Avatar
Sherwood,
I used some I bought from Summit Racing for my valve covers. It was a very faint wrinkle finish and came out well. If you put too much paint on you will lose the wrinkle effect. Pretty happy with results, but I would powdercoat if you can.
John
1985.5 944 GTS
Old 07-05-2004, 04:45 PM
Zeke's Avatar
Originally posted by North Coast Cab
Sherwood,
John
You sure? I didn't get any wrinkle until I flooded it on. Normal shops temps are best. 65* to 80* IMO. I did put the items in the sun when finished painting.
I used it on some Chevy VC's around the Corvette script ala Ferrari. Took me half a day to mask and 10 min to paint. Always the way, eh?
Old 07-05-2004, 04:50 PM
Forced Induction Junkie
WERK I's Avatar
I used PJ1 Coatings Special High Temp(500deg. F) Wrinkle Finish Paint. Put two medium coats on the valve covers and then baked at 200deg F in the oven to develop a good wrinkle texture.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-05-2004, 05:54 PM
Pat S's Avatar
I just powder coated a valve cover for my Toyota today in wrinkle red. Very Ferrari like It was the first time I coated anything with a textured finish and I'm very happy with how it turned out. I'd assume the prep work is the same for paint. I cleaned it very well with brake cleaner and a green scrubbie. Then with alcohol and a lint free cloth. I then heated it up to bake off any grease and outgas the aluminum. After that it was normal powdercoating process.
It doesn't photograph well though....
Old 07-05-2004, 06:03 PM
I baked mine and my wife was not happy with it. It turned out well though. Eastwood wrinkle paint, black.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-05-2004, 06:14 PM
Randy Webb's Avatar
Those all look great -- but aren't they hard to keep clean?
Old 07-05-2004, 09:44 PM
WERK I's Avatar
Actually, the wrinkle paint is easier to maintain than polished aluminum or a flat painted surface. I just use a soft cloth to clean them once and a while to get the dust of the valve covers. The wrinkle finish seems to scatter light so irregularities are harder to spot.
Dave
Old 07-06-2004, 06:08 AM
Bill Verburg's Avatar
30 yrs ago I used that stuff on motorcycles. Turned out great, but it is hard to keep clean
Bill Verburg
Old 07-06-2004, 06:11 AM
