Do a search for "idle hunting." You'll get some answers. I had a similar problem. I replaced the O2 sensor, the head temp sensor and the idle control valve, but nothing helped. Then someone suggested mixture. I had my mechanic tweek the mixture...problem solved. Sometimes the simplest solutions are the best.
Scott
1984 Targa |
Thanks Scott. I did find a ton of info on this on the website. Great stuff! It started right up this morning and is idling well so far, after setting the mixture last night.
Thanks again, Christian
1983 911SC Cab |
